Good morning,
Thank you for your response.
Multitech had informed me that there shouldn’t be any issues with this, but it seems that is not the case. I have an additional question regarding the gateway bridge configuration.
In my docker-compose.yml file, I have the current configuration:
version: “3”
services:
chirpstack:
image: chirpstack/chirpstack:4
command: -c /etc/chirpstack
restart: unless-stopped
volumes:
- ./lorawan-devices:/opt/lorawan-devices
depends_on:
- postgres
- mosquitto
- redis
environment:
- MQTT_BROKER_HOST=mosquitto
- REDIS_HOST=redis
- POSTGRESQL_HOST=postgres
ports:
- 8080:8080
chirpstack-gateway-bridge-eu868:
image: chirpstack/chirpstack-gateway-bridge:4
ports:
- 1701:1700/udp
volumes:
environment:
- INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/event/{{ .EventType }}
- INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/state/{{ .StateType }}
- INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=eu868/gateway/{{ .GatewayID }}/command/#
depends_on:
- mosquitto
chirpstack-gateway-bridge-au915_0:
ports:
- 1700:1700/udp
volumes:
environment:
- INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=au915_0/gateway/{{ .GatewayID }}/event/{{ .EventType }}
- INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=au915_0/gateway/{{ .GatewayID }}/state/{{ .StateType }}
- INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=au915_0/gateway/{{ .GatewayID }}/command/#
depends_on:
- mosquitto
chirpstack-rest-api:
image: chirpstack/chirpstack-rest-api:4
command: --server chirpstack:8080 --bind 0.0.0.0:8090 --insecure
ports:
- 8090:8090
depends_on:
- chirpstack
postgres:
image: postgres:14-alpine
volumes:
environment:
- POSTGRES_PASSWORD=root
redis:
image: redis:7-alpine
command: redis-server --save 300 1 --save 60 100 --appendonly no
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto:2
ports:
- 1884:1883
volumes:
- ./configuration/mosquitto/config/:/mosquitto/config/
volumes:
postgresqldata:
redisdata:
Currently, I have only enabled port 1700 for testing. When I configure port 1700 for the EU868 region, everything works fine. However, when I change the ports and use 1700 for the AU915 region, I receive the joinRequest from the device in the gateway frames, but the device does not receive any frames, and the joinRequest is not accepted.
What configuration should I adjust to make multi-region operation work correctly?
Thank you in advance for your help.
