I’m trying to build gateway-os-base using the docker method on windows 10. I’m following the exact steps described here: GitHub - chirpstack/chirpstack-gateway-os: Yocto based gateway images including ChirpStack components..
Everything is going well, except for a reccurent issue at the last stage “bitbake -k chirpstack-gateway-os-base”: 2 packages seem to fail to compile. Do you have a clue what I might be doing wrong?
It would be great if you could help as I really need to add some features to the base image (which will be yet another challenge for me) but if I can’t even manage compiling the vanilla version I guess my chances are very limited to improve on it ![]()
What seems like the relevant logs:
**** Summary
NOTE: Tasks Summary: Attempted 2357 tasks of which 426 didn’t need to be rerun and 2 failed.
Summary: 2 tasks failed:
/chirpstack-gateway-os/layers/bsp/meta-raspberrypi/recipes-kernel/linux/linux-raspberrypi_5.15.bb:do_fetch
/chirpstack-gateway-os/layers/openembedded/openembedded-core/meta/recipes-devtools/binutils/binutils-cross_2.38.bb:do_compile
Summary: There were 15 WARNING messages.
Summary: There were 4 ERROR messages, returning a non-zero exit code.
yocto@5fe7d51e2e45:/build$
**** 1
WARNING: linux-raspberrypi-1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0 do_fetch: Failed to fetch URL git://github.com/raspberrypi/linux.git;name=machine;branch=rpi-5.15.y;protocol=https, attempting MIRRORS if available
ERROR: linux-raspberrypi-1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH=“/chirpstack-gateway-os/layers/openembedded/openembedded-core/scripts:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot-native/usr/bin/arm-oe-linux-gnueabi:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot/usr/bin/crossscripts:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot-native/usr/sbin:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot-native/usr/bin:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot-native/sbin:/build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/recipe-sysroot-native/bin:/chirpstack-gateway-os/bitbake/bin:/build/tmp/raspberrypi3-glibc/hosttools”; export HOME=“/home/yocto”; LANG=C git -c core.fsyncobjectfiles=0 -c gc.autoDetach=false -c core.pager=cat clone --bare --mirror GitHub - raspberrypi/linux: Kernel source tree for Raspberry Pi-provided kernel builds. Issues unrelated to the linux kernel should be posted on the community forum at https://forums.raspberrypi.com/ /build/downloads/git2/github.com.raspberrypi.linux.git --progress failed with exit code 128, no output
ERROR: linux-raspberrypi-1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0 do_fetch: Bitbake Fetcher Error: FetchError(‘Unable to fetch URL from any source.’, ‘git://github.com/raspberrypi/linux.git;name=machine;branch=rpi-5.15.y;protocol=https’)
ERROR: Logfile of failure stored in: /build/tmp/raspberrypi3-glibc/work/raspberrypi3-oe-linux-gnueabi/linux-raspberrypi/1_5.15.34+gitAUTOINC+e1b976ee4f_0086da6acd-r0/temp/log.do_fetch.3103
ERROR: Task (/chirpstack-gateway-os/layers/bsp/meta-raspberrypi/recipes-kernel/linux/linux-raspberrypi_5.15.bb:do_fetch) failed with exit code ‘1’
**** 2 [NB: I can’t put the log to the end due to the message limitation in the forum]
ERROR: binutils-cross-arm-2.38-r0 do_compile: oe_runmake failed
ERROR: binutils-cross-arm-2.38-r0 do_compile: ExecutionError(‘/build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/run.do_compile.31101’, 1, None, None)
ERROR: Logfile of failure stored in: /build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/temp/log.do_compile.31101
Log data follows:
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files [‘endian-little’, ‘common-linux’, ‘common-glibc’, ‘bit-64’, ‘x86_64-linux’, ‘common’]
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi’
| make[1]: Nothing to be done for ‘all-target’.
| mkdir -p – ./zlib
| mkdir -p – ./libiberty
| mkdir -p – ./intl
| mkdir -p – ./etc
| mkdir -p – ./libbacktrace
| Configuring in ./intl
| Configuring in ./zlib
| Configuring in ./etc
| Configuring in ./libiberty
| Configuring in ./libbacktrace
| configure: creating cache ./config.cache
| checking for x86_64-linux-gcc… gcc
| checking whether to enable maintainer-specific portions of Makefiles… no
| checking for makeinfo… makeinfo --split-size=5000000
| checking for a BSD-compatible install… /build/tmp/raspberrypi3-glibc/hosttools/install -c
| checking whether build environment is sane… checking build system type… yes
| checking for perl… perl
| x86_64-pc-linux-gnu
| checking host system type… checking for a thread-safe mkdir -p… checking build system type… /build/tmp/raspberrypi3-glibc/hosttools/mkdir -p
| checking for gawk… gawk
| checking whether make sets $(MAKE)… checking build system type… x86_64-pc-linux-gnu
| checking target system type… x86_64-pc-linux-gnu
| checking host system type… x86_64-pc-linux-gnu
| checking host system type… arm-oe-linux-gnueabi
| yes
| checking whether make supports nested variables… checking whether the C compiler works… x86_64-pc-linux-gnu
| checking for x86_64-linux-ar… ar
| checking for x86_64-linux-ranlib… ranlib -D
| checking for -plugin option… yes
| checking whether build environment is sane… checking for x86_64-linux-ar… (cached) ar
| checking whether make supports nested variables… (cached) yes
| yes
| /chirpstack-gateway-os/layers/openembedded/openembedded-core/scripts/cross-intercept/ar: line 1: …/native-intercept/ar: No such file or directory
| configure: WARNING: Failed: ar --plugin /usr/lib/gcc/x86_64-linux-gnu/8/liblto_plugin.so rc
| no
| checking whether to install libiberty headers and static library… no
| configure: target_header_dir =
| checking for a thread-safe mkdir -p… configure: updating cache ./config.cache
| yes
| checking for C compiler default output file name… a.out
| checking whether make sets $(MAKE)… checking for suffix of executables… checking that generated files are newer than configure… checking whether the C compiler works… yes
| checking whether make supports nested variables… done
| configure: creating ./config.status
| yes
| yes
| checking for suffix of executables… checking whether make supports nested variables… (cached) yes
| checking whether we are cross compiling…
| checking whether we are cross compiling… checking whether the C compiler works… no
| checking for suffix of object files… o
| checking whether we are using the GNU C compiler… no
| checking for suffix of object files… yes
| checking for suffix of executables… checking whether the C compiler works… yes
| checking whether gcc accepts -g… o
| checking whether we are cross compiling… yes
| checking whether gcc accepts -g… yes
| checking for gcc option to accept ISO C89… yes
| checking for suffix of executables… config.status: creating Makefile
| none needed
| checking how to run the C preprocessor… gcc -E
| no
| yes
| checking for gcc option to accept ISO C89… checking for suffix of object files…
| o
| checking whether we are using the GNU C compiler… checking whether we are cross compiling… none needed
| checking whether gcc understands -c and -o together… checking for grep that handles long lines and -e… /build/tmp/raspberrypi3-glibc/hosttools/grep
| checking for egrep… /build/tmp/raspberrypi3-glibc/hosttools/grep -E
| checking for ANSI C header files… yes
| no
| yes
| checking for gcc option to accept ISO C89… make[2]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/etc’
| make[2]: Nothing to be done for ‘all’.
| make[2]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/etc’
| checking for suffix of object files… checking for grep that handles long lines and -e… o
| checking whether we are using the GNU C compiler… /build/tmp/raspberrypi3-glibc/hosttools/grep
| checking for egrep… none needed
| checking for sys/types.h… checking for grep that handles long lines and -e… /build/tmp/raspberrypi3-glibc/hosttools/grep
| checking for ANSI C header files… none needed
| checking whether gcc understands -c and -o together… yes
| checking for sys/stat.h… yes
| yes
| checking for sys/types.h… checking for stdlib.h… yes
| checking for style of include used by make… GNU
| checking dependency style of gcc … none
| checking how to print strings… yes
| printf
| checking for a sed that does not truncate output… /build/tmp/raspberrypi3-glibc/hosttools/sed
| checking for grep that handles long lines and -e… yes
| checking for sys/stat.h… /build/tmp/raspberrypi3-glibc/hosttools/grep
| checking for fgrep… /build/tmp/raspberrypi3-glibc/hosttools/grep -F
| checking for ld used by gcc … ld
| checking if the linker (ld ) is GNU ld… checking for string.h… yes
| checking for BSD- or MS-compatible name lister (nm)… /build/tmp/raspberrypi3-glibc/hosttools/nm -B
| checking the name lister (/build/tmp/raspberrypi3-glibc/hosttools/nm -B) interface… yes
| yes
| checking for stdlib.h… checking for sys/types.h… BSD nm
| checking whether ln -s works… yes
| checking the maximum length of command line arguments… yes
| 1572864
| checking whether the shell understands some XSI constructs… checking for memory.h… yes
| yes
| checking whether the shell understands “+=”… yes
| checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format… func_convert_file_noop
| checking how to convert x86_64-pc-linux-gnu file names to toolchain format… func_convert_file_noop
| checking for ld option to reload object files… -r
| checking for x86_64-linux-objdump… objdump
| checking how to recognize dependent libraries… pass_all
| checking for x86_64-linux-dlltool… dlltool
| checking how to associate runtime and link libraries… printf %s\n
| yes
| checking for string.h… checking for sys/stat.h… checking for x86_64-linux-ar… ar
| yes
| checking for strings.h… /chirpstack-gateway-os/layers/openembedded/openembedded-core/scripts/cross-intercept/ar: line 1: …/native-intercept/ar: No such file or directory
| checking for archiver @FILE support… yes
| yes
| checking for stdlib.h… checking for memory.h… yes
| checking for inttypes.h… no
| checking for x86_64-linux-strip… strip
| yes
| checking command to parse /build/tmp/raspberrypi3-glibc/hosttools/nm -B output from gcc object… yes
| checking for string.h… checking for strings.h… yes
| yes
| checking for stdint.h… checking for memory.h… yes
| checking for inttypes.h… yes
| checking for unistd.h… yes
| yes
| ok
| checking for sysroot… checking for strings.h… /build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native
| yes
| checking minix/config.h usability… checking for stdint.h… checking for x86_64-linux-mt… no
| checking for mt… no
| checking if : is a manifest tool… no
| yes
| yes
| no
| checking minix/config.h presence… checking for inttypes.h… checking for unistd.h… no
| checking for minix/config.h… no
| checking whether it is safe to define EXTENSIONS… checking for ANSI C header files… yes
| checking minix/config.h usability… yes
| checking for stdint.h… yes
| checking whether make sets $(MAKE)… yes
| no
| checking minix/config.h presence… yes
| checking whether NLS is requested… no
| checking for msgfmt… no
| checking for gmsgfmt… :
| checking for unistd.h… checking for xgettext… no
| no
| checking whether it is safe to define EXTENSIONS… checking for msgmerge… no
| yes
| checking whether build environment is sane… checking minix/config.h usability… x86_64-pc-linux-gnu
| checking host system type… yes
| x86_64-pc-linux-gnu
| checking for library containing strerror… checking for a thread-safe mkdir -p… no
| checking minix/config.h presence… /build/tmp/raspberrypi3-glibc/hosttools/mkdir -p
| checking for sys/types.h… yes
| checking whether make supports nested variables… yes
| no
| checking whether it is safe to define EXTENSIONS… yes
| checking for x86_64-linux-gcc… (cached) gcc
| none required
| checking for an ANSI C-conforming const… checking for sys/stat.h… yes
| checking for special C compiler options needed for large files… no
| checking for _FILE_OFFSET_BITS value needed for large files… yes
| checking for inline… yes
| no
| inline
| checking for off_t… checking whether gcc supports -W… checking for stdlib.h… yes
| yes
| checking whether gcc supports -Wall… checking whether we are using the GNU C compiler… (cached) yes
| checking whether gcc accepts -g… (cached) yes
| checking for gcc option to accept ISO C89… (cached) none needed
| checking whether gcc understands -c and -o together… (cached) yes
| checking for gawk… (cached) gawk
| checking for dwz… no
| checking how to print strings… checking for string.h… printf
| checking for ld used by gcc … yes
| ld
| checking if the linker (ld ) is GNU ld… yes
| checking whether gcc supports -Wwrite-strings… yes
| checking for size_t… checking for memory.h… yes
| BSD nm
| checking the maximum length of command line arguments… checking whether gcc supports -Wc+±compat… yes
| 1572864
| checking whether the shell understands some XSI constructs… yes
| checking for strings.h… checking for x86_64-linux-ar… ar
| yes
| checking whether gcc supports -Wstrict-prototypes… yes
| yes
| checking for working alloca.h… configure: WARNING: Failed: ar --plugin /usr/lib/gcc/x86_64-linux-gnu/8/liblto_plugin.so rc
| checking for archiver @FILE support… checking for inttypes.h… yes
| yes
| checking whether gcc supports -Wshadow=local… no
| checking for x86_64-linux-ranlib… (cached) ranlib -D
| checking for stdint.h… checking command to parse /build/tmp/raspberrypi3-glibc/hosttools/nm -B output from gcc object… yes
| checking for alloca… yes
| yes
| checking whether gcc supports -pedantic … checking for unistd.h… yes
| checking for stdlib.h… (cached) yes
| yes
| checking whether gcc and cc understand -c and -o together… yes
| checking for dlfcn.h… checking for unistd.h… (cached) yes
| checking for sys/param.h… yes
| ok
| checking for objdir… checking for sysroot… /build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/recipe-sysroot-native
| .libs
| yes
| checking for an ANSI C-conforming const… yes
| checking for mt… no
| checking if : is a manifest tool… checking for getpagesize… no
| checking for dlfcn.h… yes
| checking for inline… inline
| checking whether byte ordering is bigendian… checking if gcc supports -fno-rtti -fno-exceptions… yes
| checking for objdir… .libs
| yes
| checking for working mmap… no
| checking for gcc option to produce PIC… -fPIC -DPIC
| checking if gcc PIC flag -fPIC -DPIC works… yes
| checking if gcc static flag -static works… no
| checking for CET support… checking if gcc supports -fno-rtti -fno-exceptions… yes
| checking whether we are using the GNU C Library 2.1 or newer… no
| checking whether integer division by zero raises SIGFPE… yes
| checking if gcc supports -c -o file.o… yes
| checking if gcc static flag -static works… yes
| checking if gcc supports -c -o file.o… (cached) yes
| checking whether the gcc linker (ld -m elf_x86_64) supports shared libraries… yes
| checking for unsigned long long… yes
| yes
| checking whether -lc should be explicitly linked in… yes
| checking whether the gcc linker (ld -m elf_x86_64) supports shared libraries… checking for sys/file.h… yes
| yes
| checking whether -lc should be explicitly linked in… checking for sys/param.h… no
| checking dynamic linker characteristics… yes
| no
| checking dynamic linker characteristics… checking for limits.h… yes
| checking whether the inttypes.h PRIxNN macros are broken… yes
| no
| checking for ld used by GCC… ld
| checking if the linker (ld ) is GNU ld… checking for stdlib.h… (cached) yes
| yes
| checking for shared library run path origin… checking for malloc.h… yes
| GNU/Linux ld.so
| checking how to hardcode library paths into programs… immediate
| checking whether stripping libraries is possible… checking for string.h… (cached) yes
| yes
| checking if libtool supports shared libraries… yes
| checking whether to build shared libraries… yes
| checking whether to build static libraries… yes
| GNU/Linux ld.so
| checking whether stripping libraries is possible… yes
| checking for _FILE_OFFSET_BITS value needed for large files… checking for strings.h… (cached) yes
| done
| checking for sys/time.h… no
| checking unwind.h usability… yes
| checking argz.h usability… checking for stdlib.h… (cached) yes
| checking for time.h… checking for unistd.h… (cached) yes
| yes
| checking argz.h presence… yes
| checking unwind.h presence… yes
| checking for argz.h… yes
| checking for sys/resource.h… checking limits.h usability… yes
| checking for unwind.h… yes
| checking for _Unwind_Backtrace… yes
| (cached) yes
| checking for getpagesize… yes
| checking limits.h presence… checking for sys/mman.h… yes
| yes
| checking for -funwind-tables option… yes
| checking locale.h usability… checking for fcntl.h… yes
| checking for -frandom-seed=string option… yes
| yes
| checking for working mmap… yes
| yes
| checking locale.h presence… checking for alloca.h… checking whether gcc supports -W… yes
| yes
| checking for locale.h… yes
| checking nl_types.h usability… checking for sys/pstat.h… yes
| checking whether gcc supports -Wall… no
| checking for sys/sysmp.h… yes
| yes
| checking nl_types.h presence… checking whether gcc supports -Wwrite-strings… no
| yes
| checking for sys/sysinfo.h… checking for memcpy… yes
| checking for nl_types.h… yes
| yes
| yes
| checking malloc.h usability… checking for machine/hal_sysinfo.h… checking whether gcc supports -Wstrict-prototypes… yes
| no
| yes
| checking malloc.h presence… checking for sys/table.h… checking for strerror… yes
| yes
| checking whether gcc supports -Wmissing-prototypes… checking stddef.h usability… no
| checking for sys/sysctl.h… yes
| yes
| yes
| checking whether gcc supports -Wold-style-definition… checking for unistd.h… (cached) yes
| yes
| checking stddef.h presence… checking for sys/systemcfg.h… yes
| checking for stddef.h… yes
| no
| checking for stdint.h… (cached) yes
| yes
| checking whether gcc supports -Wmissing-format-attribute… checking for string.h… (cached) yes
| checking that generated files are newer than configure… done
| checking for stdio_ext.h… yes
| checking whether gcc supports -Wcast-qual… yes
| checking for sys/param.h… (cached) yes
| checking for process.h… yes
| checking for _Unwind_GetIPInfo… checking for feof_unlocked… no
| checking for sys/prctl.h… yes
| yes
| checking for CET support… yes
| checking for sys/wait.h that is POSIX.1 compatible… checking for fgets_unlocked… yes
| checking whether time.h and sys/time.h may both be included… yes
| checking whether errno must be declared… yes
| checking for getc_unlocked… no
| checking size of int… yes
| checking for getcwd… 4
| checking size of long… yes
| checking __sync extensions… yes
| 8
| checking size of size_t… checking for getegid… yes
| checking __atomic extensions… 8
| checking for long long… yes
| yes
| checking output filetype… checking for geteuid… elf64
| looking for a compliant stdint.h in stdint.h, checking for uintmax_t… yes
| yes
| checking size of long long… checking for getgid… yes
| checking for uintptr_t… yes
| 8
| checking for a 64-bit type… checking for getuid… yes
| checking for int_least32_t… uint64_t
| checking for intptr_t… yes
| checking for mempcpy… yes
| checking for int_fast32_t… yes
| checking for munmap… yes
| checking for uint64_t… yes
| checking for putenv… yes
| checking for ssize_t… yes
| checking what to include in gstdint.h… stdint.h (already complete)
| checking sys/mman.h usability… yes
| yes
| checking sys/mman.h presence… checking for setenv… yes
| checking for pid_t… yes
| checking for mmap… yes
| checking for setlocale… yes
| yes
| checking for library containing strerror… checking link.h usability… yes
| checking for stpcpy… yes
| checking link.h presence… none required
| checking for asprintf… yes
| checking for link.h… yes
| checking for dl_iterate_phdr… yes
| yes
| checking for strcasecmp… checking for atexit… yes
| checking mach-o/dyld.h usability… yes
| no
| checking mach-o/dyld.h presence… yes
| checking for strdup… checking for basename… no
| checking for mach-o/dyld.h… no
| checking sys/ldr.h usability… yes
| yes
| no
| checking sys/ldr.h presence… checking for strtoul… checking for bcmp… no
| checking for sys/ldr.h… no
| checking for fcntl… yes
| yes
| yes
| checking for tsearch… checking whether strnlen is declared… checking for bcopy… config.status: executing depfiles commands
| config.status: executing libtool commands
| yes
| yes
| checking whether getpagesize is declared… checking for __argz_count… yes
| yes
| checking for lstat… checking for bsearch… yes
| yes
| checking for __argz_stringify… yes
| checking for bzero… checking for readlink… yes
| checking for __argz_next… yes
| make[2]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/x86_64-linux/binutils-cross-arm/2.38-r0/git/build.x86_64-linux.arm-oe-linux-gnueabi/zlib’
