FATAL: remaining connection slots are reserved for non-replication superuser connections
I have 300+ sensor, and i just got err from my loraserver.
I don’t want to change my pgsql max_connections (default 100), can i do anything for it ?
Many Thanks!
I don’t know about your setup and other client connecting to the database. However in loraserver.toml (and lora-app-server.toml) you will find the following configuration in the postgresql section:
# Max open connections.
# PostgreSQL connection pool (0 = unlimited).
max_open_connections=0
# Max idle connections.
# This sets the max. number of idle connections in the PostgreSQL connection
# pool (0 = no idle connections are retained).
max_idle_connections=2
Thanks you,brocaar.
I used docker to install loraserver,which does not show this configuration
and I’ve now added this configuration to try it out
Could you solved this issue @lan ?
At times it lets me log in to the portal and when I want to send a DL it kicks me and for a few hours I get the same message “remaining connection slots are reserved for non-replication superuser connections”.
