Hi.
I’m using Temperature / Relative Humidity sensors. Using a custom payload decode function, I generate an object
objectJSON: {
"humidity": 66,
"temperature": 21.8
I can add tags to the device:
tags: {
"location": "Room 42"
Thanks to Influx integration, I can send that data to an Influx database with the tags correctly set.
The feature I’m missing is the ability to set different tags per field. I see at least two reasons for this
- add extra information, such as unit, or measure type
- add a more friendly name to display instead of device_frmpayload_data_xxx
Something like
objectJSON: {
"humidity": {"value": 66, "tags": {"unit": "%", "type": "Air relative humidity", "label": "Relative humidity"}}
"temperature": {"value": 21.8, "tags": {"unit": "°C", "type": "Air temperature", "label": "Temperature"}}
or perhaps more likely
objectJSON: {
"humidity": 66,
"temperature": 21.8
per_field_tags: {
"humidity": {"unit": "%", "type": "Air relative humidity", "label": "Relative humidity"},
"temperature": {"unit": "°C", "type": "Air temperature", "label": "Temperature"}
To achieve this, it would take
- A mechanism to define a tag mapping at device level. Not just tags, but tags that depend on the payload fields.
- A modification to the Influx integration (and perhaps other integrations if applicable) to understand this.
Thoughts?
I can’t think of a workaround. I could hardcode stuff in the decode function and use two profiles and create two devices, except I can only create one device for a devEUI and I can only associate it to a single profile.
