I have got a problem with REST API, I’m sure to get the good JWT token, I tried both method, first with jwt.io and then with /api/internal/login, none works
Note that you can past a JWT token in the console (right top). To generate one, you could use the /api/internal/login endpoint (from the api console).
Note that when you just upgraded, the default admin user is admin:admin (user:pw)
It seems that the problem is located in JWT TOKEN field or action I did a screenshot of my web console, I recovered some errors;
So I’m back with this funky issue , which is not really an issue…
I 'm afraid to tell the truth from the beginning the API works well !
So if you are sure about your token either from api/internal/login or jwt.io that you entered in the right top input field and that you retrieving “fetching ressource list undefined; Please wait.” then you only need to refresh your web page before to use the API.
As simple as that, shame on me
So to conclude everything works perfectly ( update it works only with firefox).
I want to specify that the problem persist with chrome and edge browser (in spite of global cleaning of cookies and so on) , it works only with firefox maybe someone met the same issue ?
it’s a mistake I forgot to close this topic everything work well and with all browser.
I had this isue because I hit the button enter just after wrote the jwt token…
For you question it depend on your class of your device, for example if you have class A device you can’t schedule anything go through lorawan specification.
By the way I am using Class C device.
Like we can schedule and publish downlinks using MQTT. How can we schedule Multicast downlink messages at the loraserver side??
Please provide if you have any reference related to that or else commands which can be helpful.
