I am using Chirpstack (fullOS) on a RPi 4 (4GB) and a 32GB SD card. I noticed that the gateway is no longer working while all processes etc. are all working correct.
After checking log files I found out the the filesystem is full and seems that Redis is not able to save RDB snapshots to disk due to a file system that is full (see snapshot from log)
raspberrypi4:~$ tail -f /var/log/messages
Jan 7 11:57:16 raspberrypi4 local0.warn redis[480]: Background saving error
Jan 7 11:57:22 raspberrypi4 local0.notice redis[480]: 1 changes in 120 seconds. Saving...
Jan 7 11:57:22 raspberrypi4 local0.notice redis[480]: Background saving started by pid 14004
Jan 7 11:57:22 raspberrypi4 local0.warn redis[14004]: Write error saving DB on disk: No space left on device
Jan 7 11:57:22 raspberrypi4 local0.warn redis[480]: Background saving error
Jan 07 11:57:24 raspberrypi4 user.info chirpstack-concentratord-sx1301[516]: Publishing stats event, stats_id: 2730ac58-fff1-4bec-9c0b-30ef3799667b, rx_received: 1, rx_received_ok: 1, tx_received: 0, tx_emitted: 0
Jan 7 11:57:24 raspberrypi4 user.info chirpstack-gateway-bridge[507]: time="2021-01-07T11:57:24Z" level=info msg="backend/concentratord: stats event received" stats_id=2730ac58-fff1-4bec-9c0b-30ef3799667b
Jan 7 11:57:24 raspberrypi4 user.info chirpstack-gateway-bridge[507]: time="2021-01-07T11:57:24Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=2730ac58-fff1-4bec-9c0b-30ef3799667b topic=gateway/dca632fffe817e1c/event/stats
Jan 7 11:57:24 raspberrypi4 user.err chirpstack-network-server[498]: time="2021-01-07T11:57:24Z" level=error msg="gateway/mqtt: acquire lock error" error="acquire lock error: MISCONF Redis is configured to save RDB snapshots, but it is currently not able to persist on dis
Jan 7 11:57:28 raspberrypi4 local0.notice redis[480]: 1 changes in 120 seconds. Saving...
Jan 7 11:57:28 raspberrypi4 local0.notice redis[480]: Background saving started by pid 14007
Jan 7 11:57:28 raspberrypi4 local0.warn redis[14007]: Write error saving DB on disk: No space left on device
The filesystem is full - see below:
raspberrypi4:~$ df -h
Filesystem Size Used Available Use% Mounted on
none 1.7G 8.0K 1.7G 0% /dev
/dev/mmcblk0p2 479.9M 275.5M 168.6M 62% /mnt/root
/dev/mmcblk0p4 479.9M 469.7M 0 100% /data
overlay 479.9M 469.7M 0 100% /
tmpfs 1.9G 232.0K 1.9G 0% /run
tmpfs 1.9G 320.0K 1.9G 0% /var/volatile
/dev/mmcblk0p1 39.9M 21.8M 18.1M 55% /boot
raspberrypi4:~$
Due to the above problem no LoRa messages are processed at all.
Has anybody experienced the same? And how can I prevent this from happening (e.g. can I enlarge the mounted filesystems?)
Thanks in advance
