Can someone send me the format and content of the exact package of the gateway bridge to loraserver when you send join request from node !
I’m trying to publish mqtt subject like gateway bridge and emulate join request of lora node, the node are created on the lora app server, but not yet activated ! but i’m not sur of the encode data that gateway bridge send to loraserver, this is what i try :
Python script :
import paho.mqtt.client as paho
import time
import json
broker="127.0.0.1"
port=1883
#with open("data.json", "r") as jsonFile:
# data = json.load(jsonFile)
#data = '{"rxInfo":{"mac":"a10b20c20d30e40f","time":"2019-11 25T13:45:30.937991Z","timestamp":2223916764,"frequency":868100000,"channel":0,"rfChain":1,"crcStatus":1,"codeRate":"4/5","rssi":-80,"loRaSNR":12.8,"size":23,"dataRate":{"modulation":"LORA","spreadFactor":12,"bandwidth":125},"board":0,"antenna":0},"phyPayload":"AAgHBgUEAwIBGIo3czg1MTHDwzrxBX4="}'
data = "AAEBAQEBAQEBLRIAu8zd7v+bu7Gn4ts="
while 1:
def on_publish(client,userdata,result): #create function for callback
print("data published \n")
pass
client1= paho.Client("abcdef1.....1010") #create client object
client1.on_publish = on_publish #assign function to callback
client1.connect("127.0.0.1",1883,60) #establish connection
ret= client1.publish("gateway/abcdef1.....1010/event/up",data)
time.sleep(10)
But the response of loraserver is clear, he can’t decode the message :
Loraserver Frame Log :
ERRO[1617] gateway/mqtt: unmarshal uplink frame error data_base64="MDExMTExMTExNDUxODAxODcyMDQyMjEyMzgyNTUxNTUxODcxNzcxNjcyMjYyMTk=" error="unexpected EOF"
Thanks
