mbeylis
1
Hello
We recently purchase a Kerlink IBTS Gateway
I am trying to find out if there is an easy way to have the gateway forward the LoRa payload it receives from the end device to our HTTP PHP Server?
I have configured our HTTP URL under the PUSH section of the cluster but am unsure as to how to specify the payload as a parameter to this URL?
Is this at all possible without having to actually make use of a 3rd party app making API calls using JSON
Thanks
Mark
in your php server, you create a php script that:
receive the json
decode the json
extract the payload
you can’t send just the decrypted payload from the app server.
Hi
My Java script and JSON knowledge is a bit limited.
Is there any easy example of how to receive and interprete a JSON object in a PHP Script that I can look at
I am used the parameters being defined after the ? in the URL of the PHP script. Is it different with JSON?
you don’t need to put parameters after URL for the JSON.
you create a php file on your server “reception.php”.
in app server -> integrations -> http :
uplink data URL => http://your url/reception.php"
reception.php :
$payload = file_get_contents('php://input');
$var = json_decode($payload,true);
$var2 = implode("|",$var);
$applicationID =$var['applicationID'];
$applicationName =$var['applicationName'];
$deviceName =$var['deviceName'];
$devEUI =$var['devEUI'];
$data64 = $var['data'];
foreach($var['rxInfo'] as $value)
$gatewayID =$value['gatewayID'];
$name =$value['name'];
$time =$value['time'];
$rssi =$value['rssi'];
$loRaSNR =$value['loRaSNR'];
you will receive your your data node encoded in base64, depending how you encode your data in your node, with java script you must do the reverse.
I think you have enough informations to continue
Hello
Thanks for the sample :->
I managed to find similar examples on the net and after playing around with my PHP script I eventually came right
Thanks
Mark
You can watch my play list to know how to receive data via HTTP :3 . thanks
My playlist : www.youtube.com/playlist?list=PL9FegcZTeB9LRLnXtN6OMkVSZYgHdlmOr
