I noticed that Downlink Data Fragment header generated by lora-app-server is backwards. According to specification it should be:
For example, 8th data fragment prepared by loraserver has header
08 09 00
. In my opinion (and according to specs) it should be 08 00 09
. This bug is also present in loramac-node, the header is parsed by this piece of code:
fragCounter = ( mcpsIndication->Buffer[cmdIndex++] << 0 ) & 0x00FF;
fragCounter |= ( mcpsIndication->Buffer[cmdIndex++] << 8 ) & 0xFF00;
fragIndex = ( fragCounter >> 14 ) & 0x03;
fragCounter &= 0x3FFF;
So this two implementations are kind of ‘compatible’, both use wrong headers.
Correct fragmented data generator implementation can be found in this repository and is provided by semtech.
I also stumbled upon another issue (maybe this is not issue with loraserver). I can’t send file that is over 63kB. The fragmentation session is sending file like always but the LDPC frames are not reparing lost frames corectlly. I made some tests and even with same amount of frames lost and same indexes I could send <63kB file but not file >63kB. Repaired frames were just wrong
