Hello !
I was wondering which version of the lorawan specification Loraserver implements and I can’t find out after searching.
I’m using ABP mode on a node of my LoRaWAN network in order to simulate a replay attack on it. This attack consists in replaying a packet with a random frame counter value after the node has been reset. After, the gateway will reject all the packets from that node which have a frame counter value smaller or equal to the value contained in the replayed packet.
The problem is that the counter is reset by the node’s side but not by the server’s side, which is normal according to the latest version 1.1.0. The counters shall not be reset in the node’s lifetime. However, my node does not implement the latest version, it is the 1.0.1 version or 1.0.2, it depends.
So I would like to know if it was possible that the lorawan server functions as mentioned in the 1.0.1 or 1.0.2 specification or not? And also is the loraserver functioning with the latest specification?
Thanks you for your attention,
François
