I am trying to connect multitech using basic station to the chirpsatck. I have been checking the gateway logs and for some reason the frames are getting dropped. Please find the below logs.Can you please tell where it is going wrong
root@mtcdt:/var/run/lora/1# ./station
2021-01-26 16:49:49.090 [SYS:WARN] Ignoring field: forward_crc_disabled
2021-01-26 16:49:49.115 [SYS:WARN] Ignoring field: forward_crc_error
2021-01-26 16:49:49.117 [SYS:WARN] Ignoring field: forward_crc_valid
2021-01-26 16:49:49.124 [SYS:INFO] Logging : stderr (maxsize=100000, rotate=3)
2021-01-26 16:49:49.125 [SYS:INFO] Station Ver : 2.0.5(mlinux/std) 2020-10-19 19:44:13
2021-01-26 16:49:49.126 [SYS:INFO] Package Ver : (null)
2021-01-26 16:49:49.127 [SYS:INFO] proto EUI : 80:0:a000:474d (station.conf)
2021-01-26 16:49:49.129 [SYS:INFO] prefix EUI : ::0 (station.conf)
2021-01-26 16:49:49.129 [SYS:INFO] Station EUI : 80:0:a000:474d
2021-01-26 16:49:49.130 [SYS:INFO] Station home: ./ (builtin)
2021-01-26 16:49:49.130 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-01-26 16:49:49.130 [SYS:WARN] Station in NO-CUPS mode
2021-01-26 16:49:49.333 [TCE:INFO] Starting TC engine
2021-01-26 16:49:49.345 [AIO:XDEB] [3] ws_connecting state=1
2021-01-26 16:49:49.347 [AIO:XDEB] [3] ws_connecting state=2
2021-01-26 16:49:49.347 [TCE:INFO] Connecting to INFOS: ws://192.168.1.4:3001
2021-01-26 16:49:49.351 [AIO:XDEB] [3] ws_connecting state=3
2021-01-26 16:49:49.351 [AIO:XDEB] [3|WS] > {"router":"80:0:a000:474d"}
2021-01-26 16:49:49.354 [AIO:XDEB] [3|WS] < {"router":"0080:0000:a000:474d","muxs":"0080:0000:a000:474d","uri":"ws://192.168.1.4:3001/gateway/00800000a000474d"}
2021-01-26 16:49:49.354 [TCE:INFO] Infos: 0080:0000:a000:474d 0080:0000:a000:474d ws://192.168.1.4:3001/gateway/00800000a000474d
2021-01-26 16:49:49.355 [AIO:DEBU] [3] ws_close reason=1000
2021-01-26 16:49:49.355 [AIO:DEBU] [3] Connection closed unexpectedly
2021-01-26 16:49:49.355 [AIO:DEBU] [3] WS connection shutdown...
2021-01-26 16:49:49.359 [AIO:XDEB] [3] ws_connecting state=1
2021-01-26 16:49:49.360 [AIO:XDEB] [3] ws_connecting state=2
2021-01-26 16:49:49.360 [TCE:VERB] Connecting to MUXS...
2021-01-26 16:49:49.365 [AIO:XDEB] [3] ws_connecting state=3
2021-01-26 16:49:49.365 [TCE:VERB] Connected to MUXS.
2021-01-26 16:49:49.365 [AIO:XDEB] [3|WS] > {"msgtype":"version","station":"2.0.5(mlinux/std)","firmware":null,"package":null,"model":"mlinux","protocol":2,"features":"rmtsh prod"}
2021-01-26 16:49:49.369 [AIO:XDEB] [3|WS] < {"msgtype":"router_config","NetID":null,"JoinEui":[[0,255],[65280,65535]],"region":"US902","hwspec":"sx1301/1","freq_range":[902000000,928000000],"DRs":[[10,125,0],[9,125,0],[8,125,0],[7,125,0],[8,500,0],[-1,0,0],[-1,0,0],[-1,0,0],[12,500,1],[11,500,1],[10,500,1],[9,500,1],[8,500,0],[7,500,1],[-1,0,0],[-1,0,0]],"sx1301_conf":[{"radio_0":{"enable":true,"freq":904300000},"radio_1":{"enable":true,"freq":905300000},"chan_FSK":{"enable":false},"chan_Lora_std":{"e
2021-01-26 16:49:49.369 [AIO:XDEB] [3|WS] . nable":true,"radio":0,"if":300000,"bandwidth":500000,"spread_factor":7},"chan_multiSF_0":{"enable":true,"radio":0,"if":-400000},"chan_multiSF_1":{"enable":true,"radio":0,"if":-200000},"chan_multiSF_2":{"enable":true,"radio":0,"if":0},"chan_multiSF_3":{"enable":true,"radio":0,"if":200000},"chan_multiSF_4":{"enable":true,"radio":0,"if":400000},"chan_multiSF_5":{"enable":true,"radio":1,"if":-400000},"chan_multiSF_6":{"enable":true,"radio":1,"if":-200000},"chan_
2021-01-26 16:49:49.369 [AIO:XDEB] [3|WS] . multiSF_7":{"enable":true,"radio":1,"if":0}}]}
2021-01-26 16:49:49.370 [RAL:INFO] Lora gateway library version: Version: 5.0.1-mts-5;
2021-01-26 16:49:49.418 [RAL:VERB] Connecting to device: /dev/spidev0.0
2021-01-26 16:49:49.418 [RAL:DEBU] SX130x txlut table (16 entries)
2021-01-26 16:49:49.418 [RAL:VERB] SX1301 txlut 0: dig_gain=0 pa_gain=0 dac_gain=3 mix_gain=11 rf_power=-6
2021-01-26 16:49:49.418 [RAL:VERB] SX1301 txlut 1: dig_gain=0 pa_gain=0 dac_gain=3 mix_gain=13 rf_power=-3
2021-01-26 16:49:49.418 [RAL:VERB] SX1301 txlut 2: dig_gain=0 pa_gain=1 dac_gain=3 mix_gain=9 rf_power=0
2021-01-26 16:49:49.418 [RAL:VERB] SX1301 txlut 3: dig_gain=0 pa_gain=1 dac_gain=3 mix_gain=10 rf_power=3
2021-01-26 16:49:49.418 [RAL:VERB] SX1301 txlut 4: dig_gain=0 pa_gain=1 dac_gain=3 mix_gain=12 rf_power=6
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 5: dig_gain=0 pa_gain=2 dac_gain=3 mix_gain=10 rf_power=10
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 6: dig_gain=0 pa_gain=2 dac_gain=3 mix_gain=11 rf_power=11
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 7: dig_gain=0 pa_gain=2 dac_gain=3 mix_gain=11 rf_power=12
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 8: dig_gain=2 pa_gain=2 dac_gain=3 mix_gain=12 rf_power=13
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 9: dig_gain=0 pa_gain=2 dac_gain=3 mix_gain=13 rf_power=14
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 10: dig_gain=0 pa_gain=2 dac_gain=3 mix_gain=15 rf_power=16
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 11: dig_gain=0 pa_gain=3 dac_gain=3 mix_gain=10 rf_power=20
2021-01-26 16:49:49.419 [RAL:VERB] SX1301 txlut 12: dig_gain=0 pa_gain=3 dac_gain=3 mix_gain=12 rf_power=23
2021-01-26 16:49:49.420 [RAL:VERB] SX1301 txlut 13: dig_gain=0 pa_gain=3 dac_gain=3 mix_gain=13 rf_power=25
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 txlut 14: dig_gain=0 pa_gain=3 dac_gain=3 mix_gain=15 rf_power=26
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 txlut 15: dig_gain=0 pa_gain=3 dac_gain=3 mix_gain=15 rf_power=27
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 rxrfchain 0: enable=1 freq=904.3MHz rssi_offset=-162.000000 type=2 tx_enable=1 tx_notch_freq=0
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 rxrfchain 1: enable=1 freq=905.3MHz rssi_offset=-162.000000 type=2 tx_enable=0 tx_notch_freq=0
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 ifchain 0: enable=1 rf_chain=0 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.424 [RAL:VERB] SX1301 ifchain 1: enable=1 rf_chain=0 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 2: enable=1 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 3: enable=1 rf_chain=0 freq=200000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 4: enable=1 rf_chain=0 freq=400000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 5: enable=1 rf_chain=1 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 6: enable=1 rf_chain=1 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 7: enable=1 rf_chain=1 freq=0 bandwidth=0 datarate=0 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 8: enable=1 rf_chain=0 freq=300000 bandwidth=1 datarate=2 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX1301 ifchain 9: enable=0 rf_chain=0 freq=300000 bandwidth=3 datarate=50000 sync_word=0/0
2021-01-26 16:49:49.425 [RAL:VERB] SX130x LBT not enabled
2021-01-26 16:49:49.425 [RAL:VERB] Station device: /dev/spidev0.0 (PPS capture enabled)
INFO: FPGA supported features: [TX filter] [Spectral Scan]
2021-01-26 16:49:52.479 [RAL:VERB] Concentrator started (3s52ms)
2021-01-26 16:49:52.479 [S2E:INFO] Configuring for region: US902 -- 902.0MHz..928.0MHz
2021-01-26 16:49:52.479 [S2E:VERB] DR0 SF10/BW125
2021-01-26 16:49:52.480 [S2E:VERB] DR1 SF9/BW125
2021-01-26 16:49:52.480 [S2E:VERB] DR2 SF8/BW125
2021-01-26 16:49:52.480 [S2E:VERB] DR3 SF7/BW125
2021-01-26 16:49:52.480 [S2E:VERB] DR4 SF8/BW500
2021-01-26 16:49:52.480 [S2E:VERB] DR5 undefined
2021-01-26 16:49:52.480 [S2E:VERB] DR6 undefined
2021-01-26 16:49:52.480 [S2E:VERB] DR7 undefined
2021-01-26 16:49:52.480 [S2E:VERB] DR8 SF12/BW500 (DN only)
2021-01-26 16:49:52.480 [S2E:VERB] DR9 SF11/BW500 (DN only)
2021-01-26 16:49:52.480 [S2E:VERB] DR10 SF10/BW500 (DN only)
2021-01-26 16:49:52.480 [S2E:VERB] DR11 SF9/BW500 (DN only)
2021-01-26 16:49:52.480 [S2E:VERB] DR12 SF8/BW500
2021-01-26 16:49:52.480 [S2E:VERB] DR13 SF7/BW500 (DN only)
2021-01-26 16:49:52.480 [S2E:VERB] DR14 undefined
2021-01-26 16:49:52.481 [S2E:VERB] DR15 undefined
2021-01-26 16:49:52.481 [S2E:VERB] TX power: 30.0 dBm EIRP
2021-01-26 16:49:52.481 [S2E:VERB] JoinEui list: 10 entries
2021-01-26 16:49:52.481 [S2E:VERB] NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
2021-01-26 16:49:52.481 [S2E:VERB] Dev/test settings: nocca=0 nodc=0 nodwell=0
2021-01-26 16:50:04.453 [any:XDEB] RX mod=LORA f=905100000 bw=125 sz=243 dr=2 DC0EE6A0D2848966287F13E312FB2119E0882BD44002942E88B28566A4C2639FCCDD5448DB32D51AFF2721EF275AB2818B3E9C316454155AFE977289301DBE837BDC4F4EF3AFC7B7389AF227A41D03898760E09153AF2078E544F44CEE6271708022B3E03D47DD767EEFD97C43F482BEB1C0799F7110A669FF7A742A40B395397862AA3DA4E8D3AA060D4BFF639E3F441664D08F4FCADC220DB7C3FE4C9B1BF7B219A6C1E22F08F88B0302B0A5A12C6E9F378DAB4136CFC84E7E99380FE5FA43DC06E8B39B84408477D0E3336E834EDC6C34B3B80CB521FE7
2021-01-26 16:50:04.453 [any:XDEB] **Dropped frame without CRC or with broken CRC**
