FUOTA Deployments with the Web-Interface
Hi Everyone,
I am currently trying to perform fuota using the Chirpstack.
While the fuota-feature was originally provided by the application-server, it has been moved into a separate component (the fuota-server) in December 2020. If I interpret the changes in the corresponding commit correctly, the possibility to schedule firmware updates via the web-interface has been removed with this separation. Meanwhile the fuota-server provides a gRPC-API that can be used to schedule fuota-deployments.
Is it correct that for using the fuota-feature of the Chirpstack, I would need to implement my own gRPC client first?
Best regards,
Jan
Correct. The fuota-server repo has an examples folder with a Go script to do just that.
I struggled with this for a while and eventually ended up completing a end-to-end FUOTA implementation with Chirpstack FUOTA Server. Sharing links to demo videos and post here in case if this helps in anyway.
LoRaWAN FUOTA using Chirpstack FUOTA Server
how can you access folder of main.go. I see nothing but the tomb file on my rapsberry pi when acces to folder of chirpstack-fuota-server
