Gateway and Device communication error from network to app server
Hi
I am having one strange issue- I could see in gateway bridge and then in network server for gateway stats recieving fine but in application server its not visible.
I could see following continous error in application server logs -
time=“2023-03-07T21:29:30.928615371Z” level=debug msg=“sql query executed” args=“[]” duration=1.517577ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:31.93331317Z” level=debug msg=“sql query executed” args=“[]” duration=1.308046ms query="\n\t\tselect\n\t\t\tg.
\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update”
time=“2023-03-07T21:29:32.936866292Z” level=debug msg=“sql query executed” args=“[]” duration=1.51027ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:33.940045779Z” level=debug msg=“sql query executed” args=“[]” duration=1.243449ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:34.943173784Z” level=debug msg=“sql query executed” args=“[]” duration=1.378259ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:35.946487761Z” level=debug msg=“sql query executed” args=“[]” duration=1.603167ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:36.950143827Z” level=debug msg=“sql query executed” args=“[]” duration=1.352066ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:37.952878498Z” level=debug msg=“sql query executed” args=“[]” duration=1.216004ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:38.955591032Z” level=debug msg=“sql query executed” args=“[]” duration=1.176234ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:39.958879543Z” level=debug msg=“sql query executed” args=“[]” duration=1.215971ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:40.961720868Z” level=debug msg=“sql query executed” args=“[]” duration=1.084926ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:41.965304683Z” level=debug msg=“sql query executed” args=“[]” duration=1.216952ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:42.968134869Z” level=debug msg=“sql query executed” args=“[]” duration=1.173081ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:43.972039804Z” level=debug msg=“sql query executed” args=“[]” duration=1.705817ms query="\n\t\tselect\n\t\t\tg.
time=“2023-03-07T21:29:44.975613503Z” level=debug msg=“sql query executed” args=“[]” duration=1.288405ms query=“\n\t\tselect\n\t\t\tg.\n\t\tfrom gateway g\n\t\tinner join network_server ns\n\t\t\ton ns.id = g.network_server_id\n\t\twhere\n\t\t\tns.gateway_discovery_enabled = true\n\t\t\tand g.ping = true\n\t\t\tand (g.last_ping_sent_at is null or g.last_ping_sent_at <= (now() - (interval ‘24 hours’ / ns.gateway_discovery_interval)))\n\t\torder by last_ping_sent_at\n\t\tlimit 1\n\t\tfor update"
time=“2023-03-07T21:29:45.980018082Z” level=debug msg=“sql query executed” args=“[]” duration=1.240677ms query="\n\t\tselect\n\t\t\tg.
I do not see any errors, only level=debug messages…
