oziesin
#1
Hi everyone,
I am using onion omega board.
I built gateway bridge package for mips arch. I have executeable file but i do not know how to use it.
For example i also built packet forwarder package and i copied from my ubuntu machine to onion board using scp command.
is it works same way for gateway bridge package?
i saw that i must convert to ipk package but i don’t know how to convert it.
You need to create a proper ipk package. I think brocaar uses yocto for that, but if you look at https://github.com/brocaar/chirpstack-concentratord/tree/master/packaging/vendor/multitech/conduit-ap
there is the basic structure you need to build IPK, you’ll need to modify according to your deployment-environment.
oziesin
#3
i am pretty newbie on linux and these type of files. So make me confuse when i look at. where should i start ?
oziesin
#5
The packing folder inside the chirpstack-gateway-bridge repo use for this purpose is not it ?
Especially packing/vendor/dragino/LG308 has mips architecture so am i but i faced a few errors like below when i run ./package.sh.
