Hello, Im trying to install every component in a different hosts, but after reading the documentation Im still not completely sure what else do I have to modify, first than all I istalled mosquitto in all the hosts, and set mqtt broker configuration in all the files
server="tcp://localhost:1883
so I dediced the mqtt broker is gonna be the network server, so that one says localhost, and the bridge and app server says the network server ip address, server = “tcp://192.168.1.10:1883”
same with the public ip:port of the app server api
# Public ip:port of the application-server API.
# The port must be equal to the port configured by the 'bind' flag
# above.
public_host="localhost:8001"
so I replaced localhost for the corresponding ip address.
theres another field Im not sure if I have to modify, which is the app server external api
# ip:port to bind the (user facing) http server to (web-interface and REST / gRPC api)
bind="0.0.0.0:8080"
but being honest Im not entirely sure if what Im doing is the right way to set every component in different hosts, and what else do I have to do to get it work, if any of you guys can help me a little bit I would appreciate it,
thanks.
