The problem that when I do not install the gateway bridge on gateway, and verify the ping (chirpstack gateway bridge, I can not see it receiving data from packet forwarder ( tested by ping) . on another side, when chirpstack installed on gateway, and verify receiving data, it seems work.
and based on what you comment " Choose one of them, not both, and configure bridge regarding your choice" . It seems a configuration problem, so what it the key configuration part that responsible on such things. the key configuration among all these component:
frome packet forwarder --> chirpstack-gateway-bridge --> chirpstack-network server --> chirpstack-application-server .
The packet forwarder is installed on the gateway itself.
suppose that chirpstack-gateway-bridge not on the gateway itself but on the laptop.
thus, what is the key configure 1 with 2.
cirpstack-network-server on the laptop.
thus, what is the key configure 2 with 3
chirpstack-application-server on the laptop.
thus, what is the key configure 3 and 4.
The gateway I use is multitech, and it is accessed to the internet by dhcp, and have an ip-address from the router 192.168. . .
pls help , I highly appraciate…
