Hi all, I’m using a raspberry with a 1 iC880A-SPI LoRa board from 8 months and the Gateway Bridge has never gave problems. Today, and I do not know why, it fails to start up. I tried to reboot the raspberry and I have obtained this:
Jun 18 11:37:08 raspberrypi systemd[1]: Stopped ChirpStack Gateway Bridge. Jun 18 11:37:08 raspberrypi systemd[1]: Started ChirpStack Gateway Bridge. Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: unexpected fault address 0xdcd80066 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: fatal error: fault Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: [signal SIGSEGV: segmentation violation code=0x1 addr=0xdcd80066 pc=0x21d84] Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: goroutine 1 [running, locked to thread]: Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.throw(0x5f5835, 0x5) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/panic.go:774 +0x5c fp=0x242a6c8 sp=0x242a6b4 pc=0x3f734 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.sigpanic() Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/signal_unix.go:401 +0x310 fp=0x242a6e0 sp=0x242a6c8 pc=0x54ec8 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.mapassign_faststr(0x5656f8, 0x240a020, 0x5f43f0, 0x1, 0x14) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/map_faststr.go:214 +0x30 fp=0x242a714 sp=0x242a6e4 pc=0x21d84 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: unicode.init() Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/unicode/tables.go:9 +0x3c fp=0x242a740 sp=0x242a714 pc=0x7cadc Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.doInit(0xa60c40) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:5222 +0x88 fp=0x242a754 sp=0x242a740 pc=0x4da4c Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.doInit(0xa61940) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x242a768 sp=0x242a754 pc=0x4da10 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.doInit(0xa63fb0) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x242a77c sp=0x242a768 pc=0x4da10 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.doInit(0xa64e28) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x242a790 sp=0x242a77c pc=0x4da10 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.doInit(0xa60b70) Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x242a7a4 sp=0x242a790 pc=0x4da10 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.main() Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/proc.go:190 +0x1bc fp=0x242a7e4 sp=0x242a7a4 pc=0x41594 Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: runtime.goexit() Jun 18 11:37:08 raspberrypi chirpstack-gateway-bridge[494]: /usr/local/go/src/runtime/asm_arm.s:868 +0x4 fp=0x242a7e4 sp=0x242a7e4 pc=0x6be94 Jun 18 11:37:08 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=2/INVALIDARGUMENT Jun 18 11:37:08 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 3. Jun 18 11:37:09 raspberrypi systemd[1]: Stopped ChirpStack Gateway Bridge. Jun 18 11:37:09 raspberrypi systemd[1]: Started ChirpStack Gateway Bridge. Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: unexpected fault address 0xdcd80066 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: fatal error: fault Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: [signal SIGSEGV: segmentation violation code=0x1 addr=0xdcd80066 pc=0x21d84] Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: goroutine 1 [running, locked to thread]: Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.throw(0x5f5835, 0x5) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/panic.go:774 +0x5c fp=0x1c2a6c8 sp=0x1c2a6b4 pc=0x3f734 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.sigpanic() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/signal_unix.go:401 +0x310 fp=0x1c2a6e0 sp=0x1c2a6c8 pc=0x54ec8 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.mapassign_faststr(0x5656f8, 0x1c6e000, 0x5f43f0, 0x1, 0x14) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/map_faststr.go:214 +0x30 fp=0x1c2a714 sp=0x1c2a6e4 pc=0x21d84 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: unicode.init() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/unicode/tables.go:9 +0x3c fp=0x1c2a740 sp=0x1c2a714 pc=0x7cadc Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.doInit(0xa60c40) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:5222 +0x88 fp=0x1c2a754 sp=0x1c2a740 pc=0x4da4c Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.doInit(0xa61940) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x1c2a768 sp=0x1c2a754 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.doInit(0xa63fb0) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x1c2a77c sp=0x1c2a768 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.doInit(0xa64e28) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x1c2a790 sp=0x1c2a77c pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.doInit(0xa60b70) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x1c2a7a4 sp=0x1c2a790 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.main() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/proc.go:190 +0x1bc fp=0x1c2a7e4 sp=0x1c2a7a4 pc=0x41594 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: runtime.goexit() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[499]: /usr/local/go/src/runtime/asm_arm.s:868 +0x4 fp=0x1c2a7e4 sp=0x1c2a7e4 pc=0x6be94 Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=2/INVALIDARGUMENT Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 4. Jun 18 11:37:09 raspberrypi systemd[1]: Stopped ChirpStack Gateway Bridge. Jun 18 11:37:09 raspberrypi systemd[1]: Started ChirpStack Gateway Bridge. Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: unexpected fault address 0xdcd80066 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: fatal error: fault Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: [signal SIGSEGV: segmentation violation code=0x1 addr=0xdcd80066 pc=0x21d84] Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: goroutine 1 [running, locked to thread]: Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.throw(0x5f5835, 0x5) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/panic.go:774 +0x5c fp=0x102a6c8 sp=0x102a6b4 pc=0x3f734 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.sigpanic() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/signal_unix.go:401 +0x310 fp=0x102a6e0 sp=0x102a6c8 pc=0x54ec8 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.mapassign_faststr(0x5656f8, 0x1070000, 0x5f43f0, 0x1, 0x14) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/map_faststr.go:214 +0x30 fp=0x102a714 sp=0x102a6e4 pc=0x21d84 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: unicode.init() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/unicode/tables.go:9 +0x3c fp=0x102a740 sp=0x102a714 pc=0x7cadc Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.doInit(0xa60c40) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:5222 +0x88 fp=0x102a754 sp=0x102a740 pc=0x4da4c Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.doInit(0xa61940) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x102a768 sp=0x102a754 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.doInit(0xa63fb0) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x102a77c sp=0x102a768 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.doInit(0xa64e28) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x102a790 sp=0x102a77c pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.doInit(0xa60b70) Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:5217 +0x4c fp=0x102a7a4 sp=0x102a790 pc=0x4da10 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.main() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/proc.go:190 +0x1bc fp=0x102a7e4 sp=0x102a7a4 pc=0x41594 Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: runtime.goexit() Jun 18 11:37:09 raspberrypi chirpstack-gateway-bridge[504]: /usr/local/go/src/runtime/asm_arm.s:868 +0x4 fp=0x102a7e4 sp=0x102a7e4 pc=0x6be94 Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=2/INVALIDARGUMENT Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Service RestartSec=100ms expired, scheduling restart. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 5. Jun 18 11:37:09 raspberrypi systemd[1]: Stopped ChirpStack Gateway Bridge. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Start request repeated too quickly. Jun 18 11:37:09 raspberrypi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’. Jun 18 11:37:09 raspberrypi systemd[1]: Failed to start ChirpStack Gateway Bridge.
Can someone help me?
