Recently, I was trying to build a loraserver with my RAK831+MT7628 Gateway. I met some problems. When the node send packet, the lora gateway bridge did not show any log. It just keeps looking like this:
Then I go to check my configuration. In global_conf.json, the server was setup like this
The gateway bridge configuration is:
both of them are using localhost (127.0.0.1) and port 1700. However, there is noting happen on gateway bridge log.
The network configuration of my parallel desktop virtual machine is like:
I run my packet forward and gateway bridge programs on same ubuntu platform. Only thing different, I run packet forward on Secure CRT, and run the gateway bridge on command line. Will this cause this problem? If need more picture, I can provide more details, plz help
As long as you don’t see any data in tcpdump, it means that your gateway / packet-forwarder isn’t sending any data or there is a network related issue. Maybe this is because you run things inside a VM environment? I don’t think I can help you here.
Hello, I have the exact same problems and I’m thinking that maybe the packet forwarder that i’m using is causing this disfunction. In fact I’m using a single channel packet forwarder so could that really be the cause?
