Gateway capacity
Hi! I’m trying to understand how many nodes my SX1302-based gateway can handle. I know that LoRaWAN is designed to scale, and numbers like 1,000 nodes per gateway are often mentioned online. However, only a limited number of nodes can transmit data to the gateway simultaneously.
The SF orthogonality allows, for instance, 8x8 virtual channels on the SX1302 (8 frequency channels with 8 different SFs). However, the transceiver has 16 demodulators, which means that only 16 packets can be demodulated simultaneously by the gateway.
Could anyone confirm if my understanding is correct?
It’s the developer responsability to ensure that nodes will not likely communicate simultaneously?
I think this is true only in ideal situation.
Consider also that.
Maybe you want to read this.
I would say that the responsible is your LoRaWAN library your are using together with the LNS. But I read many horror stories where developers where (ir)responsible.
Random delay, ADR, random SF, power, less bytes are some parameters that maybe as developer you may want to explore.
