Hi Guys,
I’m facing this warning:
root@debian:~# lora-gateway-bridge
INFO[0000] starting LoRa Gateway Bridge docs=“https://www.loraserver.io/lora-gateway-bridge/” version=2.5.1
INFO[0000] backend: set max reconnect interval: 10m0s
INFO[0000] backend: connecting to mqtt broker server=“tcp://127.0.0.1:1883”
INFO[0000] gateway: starting gateway udp listener addr=“0.0.0.0:1700”
INFO[0000] backend: connected to mqtt broker
INFO[0007] gateway: stat packet received addr=“192.168.200.16:45864” mac=008xxxxxxxxxxxxx
INFO[0007] backend: publishing packet qos=0 topic=gateway/008xxxxxxxxxxxxx/stats
INFO[0008] backend: subscribing to topic qos=0 topic=gateway/008xxxxxxxxxxxxx/tx
INFO[0008] backend: subscribing to topic qos=0 topic=gateway/008xxxxxxxxxxxxx/config
INFO[0037] gateway: stat packet received addr=“192.168.200.16:45864” mac=008xxxxxxxxxxxxx
INFO[0037] backend: publishing packet qos=0 topic=gateway/008xxxxxxxxxxxxx/stats
INFO[0037] backend: config packet received topic=gateway/008xxxxxxxxxxxxx/config
WARN[0037] gateway: configuration was not applied, gateway is not configured for managed configuration mac=008xxxxxxxxxxxxx
Your help is highly appreciated…
Thanks
