Gateway connecting problem
Hi guys,
I’m very new to ChirpStack and have been trying to setup ChirpStack with Docker on MacOS and a dragino LG308 gateway. I followed the instruction Dragino - ChirpStack open-source LoRaWAN® Network Server documentation to install and configure the ChirpStack Gateway Bridge on my LG308 gateway as well as Docker - ChirpStack open-source LoRaWAN® Network Server documentation to set up ChirpStack on my laptop. After I added the gateway it’s said that the gateway was never seen. Here are my chirpstack-gateway-bridge.toml configuration .What have I done wrong? Thank you so much for your help!
I’m new to CS too so I can’t help much. I see you selected protobuf, does that match with CS? Or send the chirpstack-application-server.toml file.
Please refer to this guide, it contains various examples how you can debug gateway connectivity issues:
https://www.chirpstack.io/docs/guides/connect-gateway.html
