I have a Laird rg1xx running, i got datas, uplinks, downlinks…
Then, i switched down the power and some minutes later, i switched on the gateway.
It has broken, no warning, no errors, and no infor in lora-gateway-bridge, lora-server, and lora-app-server.
I have no idea about what happen, where’s not working.
In Laird gateway interface doesn’t connect to lora again.
I tried to delete and create the gateway again (it was created with Frames received, somewhere has cache?)
I tried to restart lora-gateway-bridge, lora-server, and lora-app-server.
After reset the gateway and re-configure it, everything work again.
But i still dont know where’s no working before.
I tried to switch off and switch on some minutes again and the Laird gateway kept working without problems.
Has this happened to someone?
It seems that I am crazy.
Hello
To install lora i followed the quickstart ( I am using ubuntu in oracle VM) https://www.loraserver.io/guides/debian-ubuntu/
I have no problems, maybe you need add cors_allow_origin="*"
in lora app server config.
In laird (Sentrius RG1XX), i use Semtech forwarder.
