Gateway error using ui
I’m trying to add some features in ChirpStack UI, but get an error trying to run in with nginx.
Dockerfile
FROM nginx:1.21-alpine
RUN rm /etc/nginx/conf.d/default.conf
COPY nginx.conf /etc/nginx/conf.d
RUN rm -rf /usr/share/nginx/html/*
COPY /ui/build /usr/share/nginx/html
nginx.conf
server {
listen 80;
root /usr/share/nginx/html;
index index.html;
location /api.InternalService {
proxy_pass http://localhost:8080;
Error : POST http://localhost/api.InternalService/Settings “502 Bad Gateway”
That error means NGINX can’t proxy the request to the underlying service (http://localhost:8080).
So, how can I solve this problem. When I’m in dev, proxy works perfect, but when I run “yarn build” and put all code in nginx, nothing works. At the same time, localhost:8080 works.
So, I installed Envoy and now get this error:
"connect() failed (111: Connection refused) while connecting to upstream, client: 172.22.0.1, server: , request: “POST /api.InternalService/Settings HTTP/1.1”, upstream: “http://127.0.0.1:9000/api.InternalService/Settings”, host: “127.0.0.1”, referrer: “http://127.0.0.1/”.
Is that even possible to get working version of ui after edit and build?
I’m sorry, I can’t support you on the modifications you are making. However, the “official” ChirpStack releases are all built from source, if you make changes and follow the same build steps, then you should end up with a working ChirpStack version including your modifications.
