I saw this error when I tried to debug the lora-gateway-bridge in the Tektelic gateway that I use:
When I send downlink to the device, it’s seen in the lorawan frames and in the lora-gateway-bridge logs but the device doesn’t seem to receive it. Here are some additional information:
- Lora-gateway-bridge is installed in the gateway
- Uplinks are continuously seen in the Device Data tab of the lora-app-server
- I use US915 band
- OTAA, lorawan mac version 1.0.3A
- ADR: 0-4
- Here’s the command that I send:
Here’s the config.json file of the Tektelic gateway:
{ "SX1301_array_conf":[
"board_freq_band": "US915",
"board_rx_freq": 908600000,
"rf_chain_conf":[
"rx_enable": true,
"tx_enable": true,
"rssi_offset": -151,
"rssi_offset_coeff_a": 20,
"rssi_offset_coeff_b": 2925,
"tx_lut":[
{ "rf_power": 2, "fpga_dig_gain": 5, "ad9361_atten": 135, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -19, "ad9361_tcomp_coeff_b": 752 },
{ "rf_power": 5, "fpga_dig_gain": 5, "ad9361_atten": 122, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -19, "ad9361_tcomp_coeff_b": 752 },
{ "rf_power": 7, "fpga_dig_gain": 5, "ad9361_atten": 115, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -19, "ad9361_tcomp_coeff_b": 752 },
{ "rf_power": 9, "fpga_dig_gain": 5, "ad9361_atten": 108, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -18, "ad9361_tcomp_coeff_b": 573 },
{ "rf_power": 11, "fpga_dig_gain": 5, "ad9361_atten": 100, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -17, "ad9361_tcomp_coeff_b": 477 },
{ "rf_power": 12, "fpga_dig_gain": 5, "ad9361_atten": 96, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -16, "ad9361_tcomp_coeff_b": 264 },
{ "rf_power": 13, "fpga_dig_gain": 5, "ad9361_atten": 93, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -16, "ad9361_tcomp_coeff_b": 179 },
{ "rf_power": 14, "fpga_dig_gain": 5, "ad9361_atten": 87, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -15, "ad9361_tcomp_coeff_b": 0 },
{ "rf_power": 16, "fpga_dig_gain": 5, "ad9361_atten": 78, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -14, "ad9361_tcomp_coeff_b": -141 },
{ "rf_power": 18, "fpga_dig_gain": 5, "ad9361_atten": 69, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -13, "ad9361_tcomp_coeff_b": -550 },
{ "rf_power": 20, "fpga_dig_gain": 5, "ad9361_atten": 61, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -13, "ad9361_tcomp_coeff_b": -718 },
{ "rf_power": 22, "fpga_dig_gain": 5, "ad9361_atten": 54, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -11, "ad9361_tcomp_coeff_b": -1195 },
{ "rf_power": 24, "fpga_dig_gain": 5, "ad9361_atten": 44, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -11, "ad9361_tcomp_coeff_b": -1268 },
{ "rf_power": 25, "fpga_dig_gain": 5, "ad9361_atten": 40, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -9, "ad9361_tcomp_coeff_b": -1662 },
{ "rf_power": 26, "fpga_dig_gain": 5, "ad9361_atten": 34, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -9, "ad9361_tcomp_coeff_b": -1865 },
{ "rf_power": 27, "fpga_dig_gain": 5, "ad9361_atten": 30, "ad9361_auxdac_vref": 3, "ad9361_auxdac_word": 770, "ad9361_tcomp_coeff_a": -7, "ad9361_tcomp_coeff_b": -2102 }]
"rx_enable": true,
"tx_enable": true,
"tx_lut":[
"SX1301_conf":[
"chip_enable": true,
"chip_center_freq": 903000000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 902300000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 902500000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 902700000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 902900000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 903100000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 903300000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 903500000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 903700000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 903000000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 903000000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 904600000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 903900000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 904100000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 904300000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 904500000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 904700000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 904900000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 905100000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 905300000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 904600000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 904600000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 906200000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 905500000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 905700000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 905900000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 906100000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 906300000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 906500000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 906700000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 906900000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 906200000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 906200000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 907800000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 907100000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 907300000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 907500000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 907700000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 907900000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 908100000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 908300000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 908500000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 907800000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 907800000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 909400000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 908700000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 908900000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 909100000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 909300000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 909500000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 909700000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 909900000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 910100000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 909400000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 909400000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 911000000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 910300000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 910500000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 910700000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 910900000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 911100000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 911300000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 911500000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 911700000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 911000000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 911000000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 912600000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 911900000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 912100000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 912300000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 912500000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 912700000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 912900000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 913100000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 913300000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 912600000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 912600000, "bandwidth": 250000, "bit_rate": 100000 }
"chip_center_freq": 914200000,
"chip_rf_chain": 1,
"chan_multiSF_0": { "chan_rx_freq": 913500000, "spread_factor": "7-12" },
"chan_multiSF_1": { "chan_rx_freq": 913700000, "spread_factor": "7-12" },
"chan_multiSF_2": { "chan_rx_freq": 913900000, "spread_factor": "7-12" },
"chan_multiSF_3": { "chan_rx_freq": 914100000, "spread_factor": "7-12" },
"chan_multiSF_4": { "chan_rx_freq": 914300000, "spread_factor": "7-12" },
"chan_multiSF_5": { "chan_rx_freq": 914500000, "spread_factor": "7-12" },
"chan_multiSF_6": { "chan_rx_freq": 914700000, "spread_factor": "7-12" },
"chan_multiSF_7": { "chan_rx_freq": 914900000, "spread_factor": "7-12" },
"chan_LoRa_std" : { "chan_rx_freq": 914200000, "bandwidth": 500000, "spread_factor": 8 },
"chan_FSK" : { "chan_rx_freq": 914200000, "bandwidth": 250000, "bit_rate": 100000 }
"FSK_sync": "C194C1",
"loramac_public": true,
"dsp_stat_interval": 10,
"aes_key": "ABCDEF0123456789ABCDEF0123456789",
"calibration_temperature_celsius_room": 22,
"calibration_temperature_code_ad9361": 77
"gateway_conf": {
"gateway_ID": "647FDAFFFE0043B2",
"server_address": "127.0.0.1",
"serv_port_up": 1700,
"serv_port_down": 1700,
/* adjust the following parameters for your network */
"keepalive_interval": 10,
"stat_interval": 30,
"push_timeout_ms": 100,
/* forward only valid packets */
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false,
/* link testing mote */
"link_mote": "00CC01AF"
"gps_conf": {
"fixed_altitude": false,
"gw_altitude": 0
