Hi All,
I am trying to send a Tx by publishing to an MQTT with my Protobuf DownlinkFrame message. The gateway bridge claims it has in an invalid gateway_id, as it appears to be all zeroes. I have encoded my gateway_id as base64 in the protobuf message, however, and don’t know what is going wrong.
Here is the error from the gateway bridge:
INFO[23033] integration/mqtt: downlink frame received downlink_id=85506f95-0e60-4134-a4de-3d9e148a8e17 gateway_id=0000000000000000
ERRO[23033] send downlink frame error error=“get gateway error: gateway does not exist”
The protobuf message (not serialised) is this, which clearly has a gateway_id set at the end:
downlink_id: “\3405\361r\263\215G\340\276\3233\201aU\352\303”
items {
phy_payload: “eyJtOTcifQ==”
tx_info {
frequency: 916800000
power: 26
lora_modulation_info {
bandwidth: 125
spreading_factor: 7
code_rate: “4/5”
context: “\000\237>\253”
gateway_id: “3KYyACuL//8=”
Any advice or help would be much appreciated, as this is stopping me from sending downlinks. Thank you.
