Gateway Lorawan live frames support in chirpstack API 4.6.0
Hi Folks, I’m currently moved from chirpstack-api version 3.12.4 to chirpstack-api 4.6.0 version facing an
Issue:
from chirpstack_api import api
client = api.GatewayServiceStub(channel)
auth_token = [(“authorization”, “Bearer %s” % api_token)]
req = api.StreamGatewayFramesRequest()
req.gateway_id = id
frame_stream = client.StreamFrameLogs(req,metadata=auth_token)
(Pdb) n
AttributeError: ‘GatewayServiceStub’ object has no attribute ‘StreamFrameLogs’
When I checked in the api lib of gateway the above methods and constructs are deprecated.
OLD CHIRPSTACK API LIB
In master/python/src/chirpstack_api/as_pb/external/api/gateway_pb2.py
_STREAMGATEWAYFRAMELOGSREQUEST._serialized_start=3495
_STREAMGATEWAYFRAMELOGSREQUEST._serialized_end=3557
NEW 4.6.0 CHIRPSTACK API LIB
The below are not in new version.
Can you give pointers to resolve this dependency!!
Thanks in advance.
This part of the API is not publicly exposed (it is there to facilitate the web-interface, it can change any time):
