Hello community,
I’m using loraserver for a while without a problem. I have multitech gateways and till today I had firmware 1.4.16 installed on them.
Today I upgraded my gateways to 1.6.2 and installed a new virtual machine as my Lora Server stack (latest versions). Lora Bridge is installed on each gateway (latest version too).
My problem is that I couldn’t see any frame on the server or last activity from my gateways and I thought that it is related to the new installation, but after some hours of troubleshooting I think that there is a problem.
Take a look at my server’s logs
Oct 25 14:13:21 ip-172 mosquitto: 1540476801: Received PUBLISH from local.cid_aws_lora_server (d0, q0, r0, m0, 'gateway/0000000000000000/rx', ... (305 bytes))
Oct 25 14:13:21 ip-172 mosquitto: 1540476801: Sending PUBLISH to loraserver (d0, q0, r0, m0, 'gateway/0000000000000000/rx', ... (305 bytes))
Oct 25 14:13:21 ip-172 loraserver: time="2018-10-25T14:13:21Z" level=info msg="gateway/mqtt: uplink frame received"
Oct 25 14:13:21 ip-172 loraserver: time="2018-10-25T14:13:21Z" level=error msg="processing uplink frame error" data_base64="QNUeASaAHQABEyx8iK5RhUsFgw==" error="get device-session error: device-session does not exist or invalid fcnt or mic"
Except that the end device is not registered on my stack, (that’s the reason of the last message), I see a gateway mac of 0000000000000000 and I think that’s the problem.
I tried to subscribe to gateways mosquitto broker and the topic is still 0000000000000000. When I downgrade to multitech 1.4.16 the topic changes to something else.
So I think this is an issue with the bridge installed on multitech 1.6.2, or I’m missing something else?
thanks !
