Hi All,
i am using node-red to manipulate the payload i receive from the LoraServers.
When i look at the Data that i receive via the MQTT node i dont get all the Metadata i need.
Is there a way to send all the Metadata over MQTT, i am missing message type, rssi, and timestamp.
“applicationID”:“1”,
“applicationName”:“test”,
“deviceName”:“Gateway Test”,
“deviceProfileName”:“Class A Standard”,
“deviceProfileID”:“de26c5c2-5e9d-4325-b7a7-465fc9cd9673”,
“devEUI”:“xxxxxxxxxxxxx”,
“txInfo”:{
“frequency”:868500000,
“dr”:0
“adr”:true,
“fCnt”:653,
“fPort”:2,
“data”:“AQJX9x+2mAAJAQj+CPs=”
i figured out, that i can change the application toml to json and receive more information. Still the object rxinfo is empty.
Do you know, why Gateway metadata is not transmitted?
Thank you
