I have two gateways (a Lorank8 and a homemade RPI3/iC880A) connected to a cloud based loraserver. The gateway bridges run on the gateways. The Lorank8 is shown on the loraserver WEB GUI but the RPI3/iC880A is not, even if I disconnect the Lorank8. If I have the Lorank8 disconnected (switched off) and the RPI3/iC880A functioning, the system works, data is processed, everything fine, except the homemade RPI3/iC880A gateway is not shown under gateways.
I think gateway stats are received and processed, as shown in the (truncated) output from the loraserver log:
Dec 27 19:12:27 LoRaServer loraserver[25565]: time=“2017-12-27T19:12:27+01:00” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe3e86d6
Dec 27 19:12:27 LoRaServer loraserver[25565]: time=“2017-12-27T19:12:27+01:00” level=info msg=“gateway updated” mac=b827ebfffe3e86d6
Dec 27 19:12:57 LoRaServer loraserver[25565]: time=“2017-12-27T19:12:57+01:00” level=info msg=“backend/gateway: gateway stats packet received” mac=b827ebfffe3e86d6
Dec 27 19:12:57 LoRaServer loraserver[25565]: time=“2017-12-27T19:12:57+01:00” level=info msg=“gateway updated” mac=b827ebfffe3e86d6
In /etc/default/loraserver I have:
# create non-existing gateways on receiving of stats
GW_CREATE_ON_STATS=true
# aggregation intervals to use for aggregating the gateway stats (valid options: second, minute, hour, day, week, m$
GW_STATS_AGGREGATION_INTERVALS=minute,hour,day
loraserver version is 0.23.0,
lora-app-server version is 0.16.0
Any ideas what have I missed?
