My Lora gateway usually appears online in the ChirpStack dashboard as soon as I switch it on. However, I haven’t used the gateway for the past two weeks, and now, when I switch it on, it shows as offline in the ChirpStack dashboard. Could someone kindly help me with this issue?
And I just realized that my gateway IP address changes. Could this be the problem? If so, how can I fix it?"
You may need to put some screenshots or logs for debugging.
This is my chirpstack gateway bridge
2024-10-30 09:29:42 time="2024-10-30T01:29:42.299223156Z" level=info msg="starting ChirpStack Gateway Bridge" docs="https://www.chirpstack.io/gateway-bridge/" version=
2024-10-30 09:29:42 time="2024-10-30T01:29:42.300483759Z" level=info msg="backend/semtechudp: starting gateway udp listener" addr="0.0.0.0:1700"
2024-10-30 09:29:42 time="2024-10-30T01:29:42.304970654Z" level=warning msg="[store] memorystore wiped" module=mqtt
2024-10-30 09:29:42 time="2024-10-30T01:29:42.305043001Z" level=info msg="integration/mqtt: connected to mqtt broker"
2024-10-30 09:29:42 2024-10-30T01:29:42.272715Z INFO chirpstack::cmd::root: Starting ChirpStack LoRaWAN Network Server version="4.9.0" docs="https://www.chirpstack.io/"
2024-10-30 09:29:42 2024-10-30T01:29:42.273938Z INFO chirpstack::storage: Setting up PostgreSQL connection pool
2024-10-30 09:29:42 2024-10-30T01:29:42.276575Z INFO chirpstack::storage: Applying schema migrations
2024-10-30 09:29:42 2024-10-30T01:29:42.396245Z INFO chirpstack::storage: Setting up Redis client
2024-10-30 09:29:42 2024-10-30T01:29:42.396743Z INFO chirpstack::region: Setting up regions
2024-10-30 09:29:42 2024-10-30T01:29:42.397279Z INFO setup{common_name=AS923 region_id=as923}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397330Z INFO setup{common_name=AS923_2 region_id=as923_2}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397348Z INFO setup{common_name=AS923_3 region_id=as923_3}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397385Z INFO setup{common_name=AS923_4 region_id=as923_4}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397433Z INFO setup{common_name=AU915 region_id=au915_0}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397509Z INFO setup{common_name=CN470 region_id=cn470_10}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397557Z INFO setup{common_name=CN779 region_id=cn779}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397587Z INFO setup{common_name=EU433 region_id=eu433}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397631Z INFO setup{common_name=EU868 region_id=eu868}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397649Z INFO setup{common_name=IN865 region_id=in865}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397674Z INFO setup{common_name=ISM2400 region_id=ism2400}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397687Z INFO setup{common_name=KR920 region_id=kr920}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397728Z INFO setup{common_name=RU864 region_id=ru864}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397753Z INFO setup{common_name=US915 region_id=us915_0}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397781Z INFO setup{common_name=US915 region_id=us915_1}: chirpstack::region: Configuring region
2024-10-30 09:29:42 2024-10-30T01:29:42.397831Z INFO chirpstack::backend::joinserver: Setting up Join Server clients
2024-10-30 09:29:42 2024-10-30T01:29:42.398638Z INFO chirpstack::backend::roaming: Setting up roaming clients
2024-10-30 09:29:42 2024-10-30T01:29:42.398643Z INFO chirpstack::adr: Setting up adr algorithms
2024-10-30 09:29:42 2024-10-30T01:29:42.399688Z INFO chirpstack::integration: Setting up global integrations
2024-10-30 09:29:42 2024-10-30T01:29:42.399709Z INFO chirpstack::integration::redis: Initializing Redis integration
2024-10-30 09:29:42 2024-10-30T01:29:42.399714Z INFO chirpstack::integration::mqtt: Initializing MQTT integration
2024-10-30 09:29:42 2024-10-30T01:29:42.406693Z INFO chirpstack::integration::mqtt: Connecting to MQTT broker server_uri=tcp://mosquitto:1883/ client_id=9aca263bba15d472 clean_session=false
2024-10-30 09:29:42 2024-10-30T01:29:42.406746Z INFO chirpstack::gateway::backend: Setting up gateway backends for the different regions
2024-10-30 09:29:42 2024-10-30T01:29:42.406750Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=as923 region_common_name=AS923
2024-10-30 09:29:42 2024-10-30T01:29:42.406827Z INFO chirpstack::integration::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.407991Z INFO chirpstack::integration::mqtt: Subscribing to command topic command_topic=application/+/device/+/command/+
2024-10-30 09:29:42 2024-10-30T01:29:42.409358Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=as923 server_uri=tcp://mosquitto:1883 clean_session=false client_id=44184c3af619f3f4
2024-10-30 09:29:42 2024-10-30T01:29:42.409409Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=as923_2 region_common_name=AS923_2
2024-10-30 09:29:42 2024-10-30T01:29:42.410263Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.411030Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=as923 event_topic=$share/chirpstack/as923/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.412092Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=as923_2 server_uri=tcp://mosquitto:1883 clean_session=false client_id=dbf27cf1dd30e7d5
2024-10-30 09:29:42 2024-10-30T01:29:42.412157Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.412216Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=as923_3 region_common_name=AS923_3
2024-10-30 09:29:42 2024-10-30T01:29:42.412756Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=as923_2 event_topic=$share/chirpstack/as923_2/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.425239Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=as923_3 server_uri=tcp://mosquitto:1883 clean_session=false client_id=ceed46c5b68a30b6
2024-10-30 09:29:42 2024-10-30T01:29:42.425343Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=as923_4 region_common_name=AS923_4
2024-10-30 09:29:42 2024-10-30T01:29:42.425388Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.426222Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=as923_3 event_topic=$share/chirpstack/as923_3/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.431594Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=as923_4 server_uri=tcp://mosquitto:1883 clean_session=false client_id=1f0a464f3b817c76
2024-10-30 09:29:42 2024-10-30T01:29:42.431684Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=au915_0 region_common_name=AU915
2024-10-30 09:29:42 2024-10-30T01:29:42.431728Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.433211Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=as923_4 event_topic=$share/chirpstack/as923_4/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.440011Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=au915_0 server_uri=tcp://mosquitto:1883 clean_session=false client_id=7cf7d0f12d2f3153
2024-10-30 09:29:42 2024-10-30T01:29:42.440109Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=cn470_10 region_common_name=CN470
2024-10-30 09:29:42 2024-10-30T01:29:42.440159Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.441096Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=au915_0 event_topic=$share/chirpstack/au915_0/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.449134Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=cn470_10 server_uri=tcp://mosquitto:1883 clean_session=false client_id=4e31d4d03f5fc661
2024-10-30 09:29:42 2024-10-30T01:29:42.449211Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=cn779 region_common_name=CN779
2024-10-30 09:29:42 2024-10-30T01:29:42.449274Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.450221Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=cn470_10 event_topic=$share/chirpstack/cn470_10/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.472549Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=cn779 server_uri=tcp://mosquitto:1883 clean_session=false client_id=da8ed9e6e92cf73b
2024-10-30 09:29:42 2024-10-30T01:29:42.472630Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=eu433 region_common_name=EU433
2024-10-30 09:29:42 2024-10-30T01:29:42.472665Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.473798Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=cn779 event_topic=$share/chirpstack/cn779/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.482358Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=eu433 server_uri=tcp://mosquitto:1883 clean_session=false client_id=ab8f250aac631e29
2024-10-30 09:29:42 2024-10-30T01:29:42.482462Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=eu868 region_common_name=EU868
2024-10-30 09:29:42 2024-10-30T01:29:42.482490Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.483906Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=eu433 event_topic=$share/chirpstack/eu433/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.500655Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=eu868 server_uri=tcp://mosquitto:1883 clean_session=false client_id=c2fe8a0de8fd6546
2024-10-30 09:29:42 2024-10-30T01:29:42.500759Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=in865 region_common_name=IN865
2024-10-30 09:29:42 2024-10-30T01:29:42.500775Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.503720Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=eu868 event_topic=$share/chirpstack/eu868/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.511959Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=in865 server_uri=tcp://mosquitto:1883 clean_session=false client_id=1a7fb6a6befd2f7f
2024-10-30 09:29:42 2024-10-30T01:29:42.512119Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=ism2400 region_common_name=ISM2400
2024-10-30 09:29:42 2024-10-30T01:29:42.512176Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.513325Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=in865 event_topic=$share/chirpstack/in865/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.520697Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=ism2400 server_uri=tcp://mosquitto:1883 clean_session=false client_id=db4d4259eb22b99f
2024-10-30 09:29:42 2024-10-30T01:29:42.520791Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=kr920 region_common_name=KR920
2024-10-30 09:29:42 2024-10-30T01:29:42.520860Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.521886Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=ism2400 event_topic=$share/chirpstack/ism2400/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.531230Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=kr920 server_uri=tcp://mosquitto:1883 clean_session=false client_id=51d1463e3743d7ec
2024-10-30 09:29:42 2024-10-30T01:29:42.531319Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=ru864 region_common_name=RU864
2024-10-30 09:29:42 2024-10-30T01:29:42.531353Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.532194Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=kr920 event_topic=$share/chirpstack/kr920/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.539360Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=ru864 server_uri=tcp://mosquitto:1883 clean_session=false client_id=d317b02b300a88f2
2024-10-30 09:29:42 2024-10-30T01:29:42.539460Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=us915_0 region_common_name=US915
2024-10-30 09:29:42 2024-10-30T01:29:42.539524Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.540458Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=ru864 event_topic=$share/chirpstack/ru864/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.548256Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=us915_0 server_uri=tcp://mosquitto:1883 clean_session=false client_id=892e272e7228b46d
2024-10-30 09:29:42 2024-10-30T01:29:42.548362Z INFO chirpstack::gateway::backend: Setting up gateway backend for region region_id=us915_1 region_common_name=US915
2024-10-30 09:29:42 2024-10-30T01:29:42.548423Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.549407Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=us915_0 event_topic=$share/chirpstack/us915_0/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.560089Z INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=us915_1 server_uri=tcp://mosquitto:1883 clean_session=false client_id=479b40b92700729b
2024-10-30 09:29:42 2024-10-30T01:29:42.560204Z INFO chirpstack::downlink: Setting up Class-B/C scheduler loop
2024-10-30 09:29:42 2024-10-30T01:29:42.560227Z INFO chirpstack::downlink: Setting up multicast scheduler loop
2024-10-30 09:29:42 2024-10-30T01:29:42.560252Z INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-10-30 09:29:42 2024-10-30T01:29:42.560885Z INFO chirpstack::api: Setting up API interface bind=0.0.0.0:8080
2024-10-30 09:29:42 2024-10-30T01:29:42.561217Z INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=us915_1 event_topic=$share/chirpstack/us915_1/gateway/+/event/+
2024-10-30 09:29:42 2024-10-30T01:29:42.606311Z INFO chirpstack::api::backend: Backend interfaces API interface is disabled
2024-10-30 09:30:40 2024-10-30T01:30:40.257892Z INFO gRPC{uri=/}: chirpstack::api: Finished processing request status="200" latency=657.687µs
2024-10-30 09:30:40 2024-10-30T01:30:40.280191Z INFO gRPC{uri=/assets/index-C-P4JNPO.css}: chirpstack::api: Finished processing request status="200" latency=1.293804ms
2024-10-30 09:30:40 2024-10-30T01:30:40.286106Z INFO gRPC{uri=/assets/index-CrqxGZNA.js}: chirpstack::api: Finished processing request status="200" latency=7.144136ms
2024-10-30 09:30:40 2024-10-30T01:30:40.444589Z INFO gRPC{uri=/api.TenantService/List}: chirpstack::api: Finished processing request status="200" latency=2.09461ms
2024-10-30 09:30:40 2024-10-30T01:30:40.471737Z INFO gRPC{uri=/api.InternalService/Settings}: chirpstack::api: Finished processing request status="200" latency=735.792µs
2024-10-30 09:30:46 2024-10-30T01:30:46.075673Z INFO gRPC{uri=/api.InternalService/Login}: chirpstack::api: Finished processing request status="200" latency=5.146249ms
2024-10-30 09:30:46 2024-10-30T01:30:46.088159Z INFO gRPC{uri=/api.InternalService/Profile}: chirpstack::api: Finished processing request status="200" latency=7.849911ms
2024-10-30 09:30:46 2024-10-30T01:30:46.106448Z INFO gRPC{uri=/api.TenantService/List}: chirpstack::api: Finished processing request status="200" latency=7.355552ms
2024-10-30 09:30:46 2024-10-30T01:30:46.129994Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status="200" latency=1.913228ms
2024-10-30 09:30:46 2024-10-30T01:30:46.164023Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status="200" latency=937.873µs
2024-10-30 09:30:46 2024-10-30T01:30:46.165237Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status="200" latency=2.081521ms
2024-10-30 09:30:46 2024-10-30T01:30:46.171934Z INFO gRPC{uri=/logo.png}: chirpstack::api: Finished processing request status="200" latency=2.258853ms
2024-10-30 09:30:46 2024-10-30T01:30:46.184872Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status="200" latency=596.509µs
2024-10-30 09:30:46 2024-10-30T01:30:46.185419Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status="200" latency=1.35891ms
2024-10-30 09:30:46 2024-10-30T01:30:46.217238Z INFO gRPC{uri=/api.InternalService/GetGatewaysSummary}: chirpstack::api: Finished processing request status="200" latency=5.588972ms
2024-10-30 09:30:46 2024-10-30T01:30:46.222071Z INFO gRPC{uri=/api.InternalService/GetDevicesSummary}: chirpstack::api: Finished processing request status="200" latency=10.398817ms
2024-10-30 09:30:46 2024-10-30T01:30:46.240610Z INFO gRPC{uri=/api.GatewayService/List}: chirpstack::api: Finished processing request status="200" latency=26.873176ms
2024-10-30 09:30:46 2024-10-30T01:30:46.285135Z INFO gRPC{uri=/assets/markers-soft-BmfhfCSq.png}: chirpstack::api: Finished processing request status="200" latency=617.782µs
2024-10-30 09:30:46 2024-10-30T01:30:46.298346Z INFO gRPC{uri=/assets/fa-solid-900-QWY35r5r.woff2}: chirpstack::api: Finished processing request status="200" latency=2.592373ms
I just realized my gateway id is not listed in the log why is that?
Did you ever find any solution? Same thing’s happening with my Chirpstack
