I have been using Chirpstack for months with no issues. Today I had a power failure and I now have an issue where Chirpstack can see the rak 7268v2 gateway but no devices come online.
I have chirpstack > rak 7268v2 > mqtt running on home assistant . The config is packet forwarder.
The mqtt server sees chirpstack logging on but no data is received via mqtt about the gateway or the devices.
The rak 7268 v2 see the devices ok.
Below is the chirpstack syslog from the last reboot but I cannot see any errors or issues.
Mar 15 10:17:12 chirpv4 systemd[1]: Starting User Runtime Directory /run/user/1000…
Mar 15 10:17:12 chirpv4 systemd[1]: Finished User Runtime Directory /run/user/1000.
Mar 15 10:17:12 chirpv4 systemd[1]: Starting User Manager for UID 1000…
Mar 15 10:17:12 chirpv4 systemd[939]: Queued start job for default target Main User Target.
Mar 15 10:17:12 chirpv4 systemd[939]: Created slice User Application Slice.
Mar 15 10:17:12 chirpv4 systemd[939]: Reached target Paths.
Mar 15 10:17:12 chirpv4 systemd[939]: Reached target Timers.
Mar 15 10:17:12 chirpv4 systemd[939]: Starting D-Bus User Message Bus Socket…
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on GnuPG network certificate management daemon.
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on debconf communication socket.
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on REST API socket for snapd user session agent.
Mar 15 10:17:12 chirpv4 systemd[939]: Listening on D-Bus User Message Bus Socket.
Mar 15 10:17:12 chirpv4 systemd[939]: Reached target Sockets.
Mar 15 10:17:12 chirpv4 systemd[939]: Reached target Basic System.
Mar 15 10:17:12 chirpv4 systemd[939]: Reached target Main User Target.
Mar 15 10:17:12 chirpv4 systemd[939]: Startup finished in 69ms.
Mar 15 10:17:12 chirpv4 systemd[1]: Started User Manager for UID 1000.
Mar 15 10:17:12 chirpv4 systemd[1]: Started Session 2 of User maurice.
Mar 15 10:17:40 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:17:40.040645078Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/stats
Mar 15 10:17:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:40.040895Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/stats #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:17:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:40.442138Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::gateway#033[0m#033[2m:#033[0m Gateway state updated #033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059
Mar 15 10:17:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:40.442216Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mHOUR
Mar 15 10:17:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:40.442237Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mDAY
Mar 15 10:17:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:40.442256Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mMONTH
Mar 15 10:17:55 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:17:55.878389457Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/up uplink_id=64087
Mar 15 10:17:55 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:55.878592Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/up #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:17:56 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:56.080888Z#033[0m #033[32m INFO#033[0m #033[1mup#033[0m#033[1m{#033[0m#033[3mdeduplication_id#033[0m#033[2m=#033[0m396826eb-a033-4193-91ff-c4a7bba67acd#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::uplink#033[0m#033[2m:#033[0m Uplink received #033[3mm_type#033[0m#033[2m=#033[0mUnconfirmedDataUp
Mar 15 10:17:56 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:17:56.083174Z#033[0m #033[32m INFO#033[0m #033[1mup#033[0m#033[1m{#033[0m#033[3mdeduplication_id#033[0m#033[2m=#033[0m396826eb-a033-4193-91ff-c4a7bba67acd#033[1m}#033[0m#033[2m:#033[0m#033[1mdata_up#033[0m#033[2m:#033[0m #033[2mchirpstack::uplink::data#033[0m#033[2m:#033[0m None of the device-sessions for dev_addr resulted in valid MIC #033[3mdev_addr#033[0m#033[2m=#033[0m0070839f
Mar 15 10:18:02 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:02.389581Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/ #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m48.627µs
Mar 15 10:18:08 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:08.031853Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/static/js/main.202a8c3c.js #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m670.673µs
Mar 15 10:18:08 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:08.037527Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/static/css/main.24a18396.css #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m37.458µs
Mar 15 10:18:10 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:18:10.047706135Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/stats
Mar 15 10:18:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:10.048012Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/stats #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:18:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:10.271275Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::gateway#033[0m#033[2m:#033[0m Gateway state updated #033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059
Mar 15 10:18:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:10.271358Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mHOUR
Mar 15 10:18:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:10.271385Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mDAY
Mar 15 10:18:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:10.271404Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mMONTH
Mar 15 10:18:40 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:18:40.079580935Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/stats
Mar 15 10:18:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:40.079831Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/stats #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:18:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:40.381130Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::gateway#033[0m#033[2m:#033[0m Gateway state updated #033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059
Mar 15 10:18:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:40.381240Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mHOUR
Mar 15 10:18:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:40.381265Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mDAY
Mar 15 10:18:40 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:40.381284Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mMONTH
Mar 15 10:18:49 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:18:49.926963709Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/up uplink_id=32766
Mar 15 10:18:49 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:49.927217Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/up #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:18:50 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:50.129158Z#033[0m #033[32m INFO#033[0m #033[1mup#033[0m#033[1m{#033[0m#033[3mdeduplication_id#033[0m#033[2m=#033[0m25341474-e444-4080-b337-55dedc4c0436#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::uplink#033[0m#033[2m:#033[0m Uplink received #033[3mm_type#033[0m#033[2m=#033[0mUnconfirmedDataUp
Mar 15 10:18:50 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:18:50.130526Z#033[0m #033[32m INFO#033[0m #033[1mup#033[0m#033[1m{#033[0m#033[3mdeduplication_id#033[0m#033[2m=#033[0m25341474-e444-4080-b337-55dedc4c0436#033[1m}#033[0m#033[2m:#033[0m#033[1mdata_up#033[0m#033[2m:#033[0m #033[2mchirpstack::uplink::data#033[0m#033[2m:#033[0m None of the device-sessions for dev_addr resulted in valid MIC #033[3mdev_addr#033[0m#033[2m=#033[0m001ea96c
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.158130Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.InternalService/Profile#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m1.712827ms
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.280175Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/icon.png #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m46.429µs
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.493436Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.InternalService/Settings#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m182.654µs
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.501683Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.TenantService/Get#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m1.125313ms
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.538282Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.TenantService/Get#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m982.697µs
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.771026Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/logo.png #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m380.052µs
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.836590Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.InternalService/GetGatewaysSummary#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m1.20098ms
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.844400Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.GatewayService/List#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m1.69121ms
Mar 15 10:19:03 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:03.845009Z#033[0m #033[32m INFO#033[0m #033[1mgRPC#033[0m#033[1m{#033[0m#033[3muri#033[0m#033[2m=#033[0m/api.InternalService/GetDevicesSummary#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m2.489316ms
Mar 15 10:19:04 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:04.136890Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/ #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m28.798µs
Mar 15 10:19:05 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:05.710369Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/static/media/markers-soft@2x.1f2cc17911c8d4a3fa01.png #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m464.909µs
Mar 15 10:19:05 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:05.710794Z#033[0m #033[32m INFO#033[0m #033[1mhttp#033[0m#033[1m{#033[0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033[3muri#033[0m#033[2m=#033[0m/static/media/fa-solid-900.fb8184add5a3101ad0a3.woff2 #033[3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::api#033[0m#033[2m:#033[0m Finished processing request #033[3mstatus#033[0m#033[2m=#033[0m"200" #033[3mlatency#033[0m#033[2m=#033[0m891.448µs
Mar 15 10:19:10 chirpv4 chirpstack-gateway-bridge[710]: time=“2024-03-15T10:19:10.106699224Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=eu868/gateway/ac1f09fffe0b8059/event/stats
Mar 15 10:19:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:10.107134Z#033[0m #033[32m INFO#033[0m #033[2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033[0m Message received from gateway #033[3mregion_id#033[0m#033[2m=#033[0m"eu868" #033[3mtopic#033[0m#033[2m=#033[0meu868/gateway/ac1f09fffe0b8059/event/stats #033[3mqos#033[0m#033[2m=#033[0mAtMostOnce #033[3mjson#033[0m#033[2m=#033[0mtrue
Mar 15 10:19:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:10.655785Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::gateway#033[0m#033[2m:#033[0m Gateway state updated #033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059
Mar 15 10:19:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:10.655856Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mHOUR
Mar 15 10:19:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:10.655879Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mDAY
Mar 15 10:19:10 chirpv4 chirpstack[789]: #033[2m2024-03-15T10:19:10.655897Z#033[0m #033[32m INFO#033[0m #033[1mstats#033[0m#033[1m{#033[0m#033[3mgateway_id#033[0m#033[2m=#033[0mac1f09fffe0b8059#033[1m}#033[0m#033[2m:#033[0m #033[2mchirpstack::storage::metrics#033[0m#033[2m:#033[0m Metrics saved #033[3mname#033[0m#033[2m=#033[0mgw:ac1f09fffe0b8059 #033[3maggregation#033[0m#033[2m=#033[0mMONTH
Any ideas as to whjat may have gone wrong?
