Hello community,
I use several Dragino gateways type LG308 and LPS8N. Yesterday I attempted the Mqtt Forwarder installation. The guides “Mosquitto TLS Configuration” and “Mqtt-Forwarder” were very helpful, so the Mqtt Forwarder runs over TLS on port 8883.
But the Chirpstack server only shows the gateway online, but I don’t get any sensor data via the same gateway?
Any idea why this is?
Kind regards
Bastian
I solved the problem earlier: I had set json=true, so it didn’t work. With json=false i.e. protobuf the sensor data comes in again.
Thanks for the help anyway
You have to tell us you changed the json=true/false next time.
This is not a guessing challenge.
That’s not what it was meant to be. So far I have always been able to use both settings… at least with the Gateway Bridge and so far I have always received sensor data as soon as a gateway was online.
