we decided to start using Chirpstack. We bought the RAK2245 and we setup the CS server remotely from the Gateway. Our sensor is setup for US freq. so we have setup the GW for US channels.
The transmission from the sensor is received as we can see the “UnconfirmedDataUp” (and down) message in the app. server.
The problem is that the second (or any thereafter) message transmitted by the sensor are not being received. Not until we reset the sensor, another message is received in the app. server.
I checked the log in the GW and I noticed that although a message is picked up by the GW, it is not doing anything with this… :
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # RF packets received by concentrator: 1
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # RF packets forwarded: 1 (28 bytes)
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # PUSH_DATA datagrams sent: 2 (326 bytes)
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # PUSH_DATA acknowledged: 0.00%
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: ### [DOWNSTREAM] ###
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # PULL_DATA sent: 3 (100.00% acknowledged)
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # PULL_RESP(onse) datagrams received: 1 (202 bytes)
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # RF packets sent to concentrator: 1 (22 bytes)
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # TX errors: 0
Nov 30 21:32:43 rak-gateway ttn-gateway[1144]: # TX rejected (collision packet): 0.00% (req:10, rej:0)
VS
[UPSTREAM]
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # RF packets received by concentrator: 0
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # RF packets forwarded: 0 (0 bytes)
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # PUSH_DATA datagrams sent: 1 (111 bytes)
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # PUSH_DATA acknowledged: 0.00%
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: ### [DOWNSTREAM] ###
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # PULL_DATA sent: 3 (100.00% acknowledged)
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # RF packets sent to concentrator: 0 (0 bytes)
Nov 30 21:34:15 rak-gateway ttn-gateway[1144]: # TX errors: 0
Is this a frequency issue…?
I only setup the freq. plan in the GW (gateway-config) to US. Is there anything else that needs to be setup in the Gateway
Thanks
Henk
