Please note:
The channels active in this gateway-profile as specified in the LoRaWAN Regional Parameters sepecification. Separate channels by comma, e.g. 0, 1, 2. Extra channels must not be included in this list.
For the EU band the Enabled channels should be: 0, 1, 2.
In the latest LoRa App Server release the channel-configuration has been renamed to gateway-profiles as this profile allows you to configure the gateway channel-plans. This does not reflect the device channel configuration. E.g. for EU you could have two gateway-profiles with 8 channels each. Then using the [[network_server.network_settings.extra_channels]] you would configure all 16 channels if you would like to enable these on your devices.
See also:
