This release deprecates the LoRa Channel Manager component and implements the packet-forwarder configuration management (for channel configuration) in LoRa Gateway Bridge.
Changelogs
LoRa App Server 0.20.0
Features:
- (Gateway) channel-configuration has been refactored into gateway-profiles.
- This requires LoRa Server 0.26.0 or up.
- This removes the channel-configuration related gateway API methods.
- This adds gateway-profile API methods.
Bugfixes:
Upgrade notes:
In order to automatically migrate the existing channel-configuration into the
new gateway-profiles, first upgrade LoRa Server and restart it. After upgrading
LoRa App Server and restarting it, all channel-configurations will be migrated
and associated to the gateways. As always, it is advised to first make a backup
of your (PostgreSQL) database.
LoRa Server 0.26.0
Features:
(Gateway) channel-configuration has been refactored into gateway-profiles and
configuration updates are now sent over MQTT to the gateway.- This requires LoRa Gateway Bridge 2.4.0 or up.
- This requires LoRa App Server 0.20.0 or up.
- This deprecates the LoRa Channel Manager service.
- This removes the
GatewaygRPC service (which was running by default on port8002). - This removes the channel-configuration related gRPC methods from the
NetworkServergRPC service. - This adds gateway-profile related gRPC methods to the
FSK support when permitted by the LoRaWAN ISM band.
- Note that the ADR engine will only use the data-rates of the pre-defined multi data-rate channels.
Bugfixes:
- Fix leaking Redis connections on pubsub subscriber (#313.
Upgrade notes:
Features:
- LoRa Gateway Bridge can now manage the packet-forwarder configuration (channels).
See Send / receive data for more information.
This has been updated.
