Hi, my gateway shown last seen at never. When i register the gateway in the TTN, the gateway was connected perfectly. However, when i tried to connect to the chirpstack. The Data ack was not shown. I don’t know what is the problem. I have installed all the three component on the server and i have risinghf mini kit gateway. I guess the packet forwarder was working fine since i can connect it with ttn.
Here the packet forwarder log file:
*** Beacon Packet Forwarder for Lora Gateway ***
Version: 3.0.0
*** Lora concentrator HAL library version info ***
Version: 4.0.1;
INFO: Little endian host
INFO: found global configuration file global_conf.json, parsing it
INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1 301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -16 6.000000, tx enabled 1
INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -16 6.000000, tx enabled 0
INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing ga teway parameters
INFO: gateway MAC address is configured to B827EBFFFE5BA6AE
INFO: server hostname or IP address is configured to "10.207.165.17"
INFO: upstream port is configured to "1700"
INFO: downstream port is configured to "1700"
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: packets received with a valid CRC will be forwarded
INFO: packets received with a CRC error will NOT be forwarded
INFO: packets received with no CRC will NOT be forwarded
INFO: Auto-quit after 3 non-acknowledged PULL_DATA
INFO: found local configuration file local_conf.json, parsing it
INFO: redefined parameters will overwrite global parameters
INFO: local_conf.json does not contain a JSON object named SX1301_conf
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gat eway parameters
INFO: [main] concentrator started, packet can now be received
INFO: Disabling GPS mode for concentrator's counter...
INFO: host/sx1301 time offset=(1659083193s:700574µs) - drift=1751765214µs
INFO: Enabling GPS mode for concentrator's counter.
##### 2022-07-29 08:27:06 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 0
# CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 0 (0 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (0.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
src/jitqueue.c:511:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# GPS sync is disabled
##### END #####
JSON up: {"stat":{"time":"2022-07-29 08:27:06 GMT","rxnb":0,"rxok":0,"rxfw":0,"a ckr":0.0,"dwnb":0,"txnb":0}}
INFO: [down] the last 3 PULL_DATA were not ACKed, exiting application
INFO: End of downstream thread
INFO: End of upstream thread
##### 2022-07-29 08:27:36 GMT #####
### [UPSTREAM] ###
# PUSH_DATA datagrams sent: 1 (111 bytes)
# PULL_DATA sent: 0 (0.00% acknowledged)
# TX errors: 0
# BEACON queued: 0
### [JIT] ###
### [GPS] ###
##### END #####
INFO: concentrator stopped successfully
INFO: Exiting packet forwarder program
**Here my chirpstack-gateway-bridge.toml :**
[general]
log_level=4
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=false
# Filters.
# These can be used to filter LoRaWAN frames to reduce bandwith usage between
# the gateway and ChirpStack Gateway Bridge. Depending the used backend, filtering
# will be performed by the Packet Forwarder or ChirpStack Gateway Bridge.
[filters]
# NetIDs filters.
# The configured NetIDs will be used to filter uplink data frames.
# When left blank, no filtering will be performed on NetIDs.
# Example:
# net_ids=[
# "000000",
# "000001",
net_ids=[
# JoinEUI filters.
# The configured JoinEUI ranges will be used to filter join-requests.
# When left blank, no filtering will be performed on JoinEUIs.
# Example:
# join_euis=[
# ["0000000000000000", "00000000000000ff"],
# ["000000000000ff00", "000000000000ffff"],
join_euis=[
[backend]
# Backend type.
# Valid options are:
# * semtech_udp
# * concentratord
# * basic_station
type="semtech_udp"
# Backend type.
# * semtech_udp
# * concentratord
# * basic_station
type="semtech_udp"
# Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
# ip:port to bind the UDP listener to
# Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
# This is the listener to which the packet-forwarder forwards its data
# so make sure the 'serv_port_up' and 'serv_port_down' from your
# packet-forwarder matches this port.
udp_bind = "0.0.0.0:1700"
# Skip the CRC status-check of received packets
# This is only has effect when the packet-forwarder is configured to forward
# LoRa frames with CRC errors.
skip_crc_check = true
# Fake RX timestamp.
# Fake the RX time when the gateway does not have GPS, in which case
# the time would otherwise be unset.
fake_rx_time=false
# ChirpStack Concentratord backend.
[backend.concentratord]
# Check for CRC OK.
crc_check=true
# Event API URL.
event_url="ipc:///tmp/concentratord_event"
# Command API URL.
command_url="ipc:///tmp/concentratord_command"
# Basic Station backend.
[backend.basic_station]
# ip:port to bind the Websocket listener to.
bind=":3001"
# TLS certificate and key files.
# When set, the websocket listener will use TLS to secure the connections
# between the gateways and ChirpStack Gateway Bridge (optional).
tls_cert=""
tls_key=""
# TLS CA certificate.
# When configured, ChirpStack Gateway Bridge will validate that the client
# certificate of the gateway has been signed by this CA certificate.
ca_cert=""
# Stats interval.
# This defines the interval in which the ChirpStack Gateway Bridge forwards
# the uplink / downlink statistics.
stats_interval="30s"
# Ping interval.
ping_interval="1m0s"
# Timesync interval.
# This defines the interval in which the ChirpStack Gateway Bridge sends
# a timesync request to the gateway. Setting this to 0 disables sending
# timesync requests.
timesync_interval="1h0m0s"
# Read timeout.
# This interval must be greater than the configured ping interval.
read_timeout="1m5s"
# Write timeout.
write_timeout="1s"
# Region.
# Please refer to the LoRaWAN Regional Parameters specification
# for the complete list of common region names.
region="EU868"
# Minimal frequency (Hz).
frequency_min=863000000
# Maximum frequency (Hz).
frequency_max=870000000
# Concentrator configuration.
# This section contains the configuration for the SX1301 concentrator chips.
# Example:
# [[backend.basic_station.concentrators]]
# # Multi-SF channel configuration.
# [backend.basic_station.concentrators.multi_sf]
# # Frequencies (Hz).
# frequencies=[
# 868100000,
# 868300000,
# 868500000,
# 867100000,
# 867300000,
# 867500000,
# 867700000,
# 867900000,
# # LoRa STD channel.
# [backend.basic_station.concentrators.lora_std]
# # Frequency (Hz).
# frequency=868300000
# # Bandwidth (Hz).
# bandwidth=250000
# # Spreading factor.
# spreading_factor=7
# # FSK channel.
# [backend.basic_station.concentrators.fsk]
# # Frequency (Hz).
# frequency=868800000
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="protobuf"
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic_template="gateway/{{ .GatewayID }}/event/{{ .EventType }}"
# State topic template.
# States are sent by the gateway as retained MQTT messages (by default)
# so that the last message will be stored by the MQTT broker. When set to
# a blank string, this feature will be disabled. This feature is only
# supported when using the generic authentication type.
state_topic_template="gateway/{{ .GatewayID }}/state/{{ .StateType }}"
# Command topic template.
command_topic_template="gateway/{{ .GatewayID }}/command/#"
# State retained.
# By default this value is set to true and states are published as retained
# MQTT messages. Setting this to false means that states will not be retained
# by the MQTT broker.
state_retained=true
# Keep alive will set the amount of time (in seconds) that the client should
# wait before sending a PING request to the broker. This will allow the client
# to know that a connection has not been lost with the server.
# Valid units are 'ms', 's', 'm', 'h'. Note that these values can be combined, e.g. '24h30m15s'.
keep_alive="30s"
# Maximum interval that will be waited between reconnection attempts when connection is lost.
max_reconnect_interval="1m0s"
# Terminate on connect error.
# When set to true, instead of re-trying to connect, the ChirpStack Gateway Bridge
# process will be terminated on a connection error.
terminate_on_connect_error=false
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
# MQTT servers.
# Configure one or multiple MQTT server to connect to. Each item must be in
# the following format: scheme://host:port where scheme is tcp, ssl or ws.
servers=[
"tcp://10.207.165.17:1883",
username=""
username=""
password=""
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=true
# Client ID
client_id=""
ca_cert=""
# mqtt TLS certificate file (optional)
tls_cert=""
# mqtt TLS key file (optional)
tls_key=""
# Google Cloud Platform Cloud IoT Core authentication.
# Please note that when using this authentication type, the MQTT topics
# will be automatically set to match the MQTT topics as expected by
# Cloud IoT Core.
[integration.mqtt.auth.gcp_cloud_iot_core]
# MQTT server.
server="ssl://mqtt.googleapis.com:8883"
# Google Cloud IoT Core Device id.
device_id=""
# Google Cloud project id.
project_id=""
# Google Cloud region.
cloud_region=""
# Google Cloud IoT registry id.
registry_id=""
# JWT token expiration time.
jwt_expiration="24h0m0s"
# JWT token key-file.
# Example command to generate a key-pair:
# $ ssh-keygen -t rsa -b 4096 -f private-key.pem
# $ openssl rsa -in private-key.pem -pubout -outform PEM -out public-key.pem
# Then point the setting below to the private-key.pem and associate the
# public-key.pem with this device / gateway in Google Cloud IoT Core.
jwt_key_file=""
# Azure IoT Hub
# This setting will preset uplink and downlink topics that will only
# work with Azure IoT Hub service.
[integration.mqtt.auth.azure_iot_hub]
# Device connection string (symmetric key authentication).
# This connection string can be retrieved from the Azure IoT Hub device
# details when using the symmetric key authentication type.
device_connection_string=""
# Token expiration (symmetric key authentication).
# ChirpStack Gateway Bridge will generate a SAS token with the given expiration.
# After the token has expired, it will generate a new one and trigger a
# re-connect (only for symmetric key authentication).
sas_token_expiration="24h0m0s"
# Device ID (X.509 authentication).
# This will be automatically set when a device connection string is given.
# It must be set for X.509 authentication.
device_id=""
# IoT Hub hostname (X.509 authentication).
# Example: iot-hub-name.azure-devices.net
hostname=""
# Client certificates (X.509 authentication).
# Configure the tls_cert (certificate file) and tls_key (private-key file)
# when the device is configured with X.509 authentication.
tls_cert=""
tls_key=""
# Metrics configuration.
[metrics]
# Metrics stored in Prometheus.
# These metrics expose information about the state of the ChirpStack Gateway Bridge
# instance like number of messages processed, number of function calls, etc.
[metrics.prometheus]
# Expose Prometheus metrics endpoint.
endpoint_enabled=false
# The ip:port to bind the Prometheus metrics server to for serving the
# metrics endpoint.
bind=""
# Gateway meta-data.
# The meta-data will be added to every stats message sent by the ChirpStack Gateway
# Bridge.
[meta_data]
# Static.
# Static key (string) / value (string) meta-data.
[meta_data.static]
# Example:
# serial_number="A1B21234"
# Dynamic meta-data.
# Dynamic meta-data is retrieved by executing external commands.
# This makes it possible to for example execute an external command to
# read the gateway temperature.
[meta_data.dynamic]
# Execution interval of the commands.
execution_interval="1m0s"
# Max. execution duration.
max_execution_duration="1s"
# Split delimiter.
# When the output of a command returns multiple lines, ChirpStack Gateway Bridge
# assumes multiple values are returned. In this case it will split by the given delimiter
# to obtain the key / value of each row. The key will be prefixed with the name of the
# configured command.
split_delimiter="="
# Commands to execute.
# The value of the stdout will be used as the key value (string).
# In case the command failed, it is ignored. In case the same key is defined
# both as static and dynamic, the dynamic value has priority (as long as the)
# command does not fail.
[meta_data.dynamic.commands]
# Example:
# temperature="/opt/gateway-temperature/gateway-temperature.sh"
# Executable commands.
# The configured commands can be triggered by sending a message to the
# ChirpStack Gateway Bridge.
[commands]
# Example:
# [commands.commands.reboot]
# max_execution_duration="1s"
# command="/usr/bin/reboot"
i run journalctl -u chirpstack-gateway-bridge -f -n 50:
i run journalctl -u chirpstack-network-server -f -n 50:
i run journalctl -u chirpstack-application-server -f -n 50:
Please help me, i’ve been working on this for 3 month but no progress at all.
