Gateway Raspberry iC880A-SPI
i got a Raspberry Pi connected to a iC880A-SPI LoRaWAN concentrator Board and a Ubuntu Server on Azure on which i run Chirpstack Gateway Bridge, Chirpstack-Network-Server and Chirpstack Application Server.
My Chirpstack Application shows only : never seen for my gateway, do you have an idea what it could be ?
Check the gateway’s logs to see if the packet forwarder is actually running and see if it’s getting protocol acks back from the gateway bridge (it would really be better to run the gateway bridge locally on the gateway itself though).
Also check the gateways logs to see if it is receiving any actual packets from nodes.
