Hello all, my setup is
an Rpi 4, RAK2287 and I am trying to setup ChirpStack Gateway OS
My problem is that GatewayId seems offline, but I cant understand from logs what my issue could be
If someone can guide me it would be very helpful
Fri Apr 19 08:07:27 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514047.262312999s
Fri Apr 19 08:07:28 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514048.262467387s
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Starting ChirpStack MQTT Forwarder (version: 4.1.3, docs: https://www.chirpstack.io/)
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Setting up ChirpStack Concentratord backend
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Connecting to Concentratord event API, event_url: ipc:///tmp/concentratord_event
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Connecting to Concentratord command API, command_url: ipc:///tmp/concentratord_command
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Reading gateway id
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Received gateway id, gateway_id: 0016c001f11911b1
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Received Gateway ID from backend, gateway_id: 0016c001f11911b1
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Connecting to MQTT broker, server: tcp://localhost:1883, clean_session: false, client_id: 0016c001f11911b1, qos: 0
Fri Apr 19 08:07:28 2024 daemon.notice mosquitto[1454]: 1713514048: New connection from 127.0.0.1:42194 on port 1883.
Fri Apr 19 08:07:28 2024 daemon.notice mosquitto[1454]: 1713514048: New client connected from 127.0.0.1:42194 as 0016c001f11911b1 (p2, c0, k60).
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Connected to MQTT broker
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Subscribing to command topic, topic: eu868/gateway/0016c001f11911b1/command/+
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Starting MQTT consumer loop
Fri Apr 19 08:07:28 2024 user.info chirpstack-mqtt-forwarder[2947]: Sending conn state, topic: eu868/gateway/0016c001f11911b1/state/conn
Fri Apr 19 08:07:29 2024 daemon.info hostapd: phy0-ap0: STA 84:5c:f3:c8:3a:5c IEEE 802.11: associated
Fri Apr 19 08:07:29 2024 daemon.notice hostapd: phy0-ap0: AP-STA-CONNECTED 84:5c:f3:c8:3a:5c auth_alg=open
Fri Apr 19 08:07:29 2024 daemon.info hostapd: phy0-ap0: STA 84:5c:f3:c8:3a:5c WPA: pairwise key handshake completed (RSN)
Fri Apr 19 08:07:29 2024 daemon.notice hostapd: phy0-ap0: EAPOL-4WAY-HS-COMPLETED 84:5c:f3:c8:3a:5c
Fri Apr 19 08:07:29 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514049.262625424s
Fri Apr 19 08:07:30 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514050.262778812s
Fri Apr 19 08:07:30 2024 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(phy0-ap0) 192.168.0.191 84:5c:f3:c8:3a:5c
Fri Apr 19 08:07:30 2024 daemon.info dnsmasq-dhcp[1]: DHCPACK(phy0-ap0) 192.168.0.191 84:5c:f3:c8:3a:5c GRTH0019
Fri Apr 19 08:07:30 2024 daemon.warn dnsmasq[1]: possible DNS-rebind attack detected: dns.msftncsi.com
Fri Apr 19 08:07:30 2024 daemon.warn dnsmasq[2]: possible DNS-rebind attack detected: dns.msftncsi.com
Fri Apr 19 08:07:31 2024 daemon.err uwsgi[1249]: *** has_emperor mode detected (fd: 7) ***
Fri Apr 19 08:07:31 2024 daemon.err uwsgi[1249]: [uWSGI] getting INI configuration from /etc/uwsgi/vassals/luci-webui.ini
Fri Apr 19 08:07:31 2024 daemon.err uwsgi[1249]: Fri Apr 19 08:07:31 2024 - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini has been spawned
Fri Apr 19 08:07:31 2024 daemon.info uwsgi-luci: spawned uWSGI master process (pid: 2966)
Fri Apr 19 08:07:31 2024 daemon.err uwsgi[1249]: Fri Apr 19 08:07:31 2024 - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini is ready to accept requests
Fri Apr 19 08:07:31 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514051.262947682s
Fri Apr 19 08:07:31 2024 daemon.err uwsgi[1249]: Fri Apr 19 08:07:31 2024 - [emperor] vassal /etc/uwsgi/vassals/luci-webui.ini is now loyal
Fri Apr 19 08:07:32 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514052.263113459s
Fri Apr 19 08:07:33 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514053.263268736s
Fri Apr 19 08:07:34 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514054.263634699s
Fri Apr 19 08:07:35 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514055.263788531s
Fri Apr 19 08:07:36 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514056.263984679s
Fri Apr 19 08:07:37 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514057.264186789s
Fri Apr 19 08:07:38 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514058.264382344s
Fri Apr 19 08:07:39 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514059.264591511s
Fri Apr 19 08:07:40 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514060.264783788s
Fri Apr 19 08:07:41 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514061.264987157s
Fri Apr 19 08:07:42 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514062.265172879s
Fri Apr 19 08:07:42 2024 cron.err crond[1130]: time disparity of 1513 minutes detected
Fri Apr 19 08:07:43 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514063.265363379s
Fri Apr 19 08:07:44 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514064.2655571s
Fri Apr 19 08:07:45 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514065.265765044s
Fri Apr 19 08:07:46 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514066.265969432s
Fri Apr 19 08:07:47 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514067.266182246s
Fri Apr 19 08:07:48 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514068.266368301s
Fri Apr 19 08:07:49 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514069.266565782s
Fri Apr 19 08:07:50 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514070.266763578s
Fri Apr 19 08:07:51 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514071.266958707s
Fri Apr 19 08:07:52 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514072.267163836s
Fri Apr 19 08:07:53 2024 user.info chirpstack-concentratord-sx1302[2122]: Publishing stats event, rx_received: 0, rx_received_ok: 0, tx_received: 0, tx_emitted: 0
Fri Apr 19 08:07:53 2024 user.info chirpstack-mqtt-forwarder[2947]: Received gateway stats
Fri Apr 19 08:07:53 2024 user.info chirpstack-mqtt-forwarder[2947]: Sending gateway stats event, topic: eu868/gateway/0016c001f11911b1/event/stats
Fri Apr 19 08:07:53 2024 user.warn chirpstack-concentratord-sx1302[2122]: GPS time reference is not valid, age: 1713514073.267383743s
Fri Apr 19 08:07:53 2024 user.info chirpstack-mqtt-forwarder[2947]: Received message, topic: eu868/gateway/0016c001f11911b1/command/config, qos: 0
