I have a device - which has existed on a different NOC server in the past, which I am now switching to ChirpStack.
The uplink data is received in the gateway and received at the application server. However, but never makes it into the “application” - which has the correct DEVEUI + APPKey.
On the network server log I see the following:
Jun 03 21:20:21 chirp-stack-pn-1 chirpstack-network-server[9309]: time=“2020-06-03T21:20:21Z” level=error msg=“uplink: processing uplink frame error” ctx_id=f2d483e7-155f-49fd-b972-a0504cbf92dd error=“get device-session error: object does not exist”
And in the Postgres database I can see the following:
chirpstack_ns_ns=> select * from device_activation;
id | created_at | dev_eui | join_eui | dev_addr | f_nwk_s_int_key | s_nwk_s_int_key | nwk_s_enc_key | dev_nonce | join_req_type
(0 rows)
My question: if I have the session key (which I do), how can I add it into the ChirpStack system? I don’t want to rejoin this device to the ChirpStack system, as I risk needing to restart the device. I cannot restart it due to its current location - which is inaccessible.
Thanks for your help
