Hello @brocaar !
I’m really new to all of this, by the way thank you for your great job!
I’m trying to execute chirpstack application server from source code. What I’ve done:
- Cloned chirpstack app server
- Executed
make build
command in app server directory
- Got an error:
static/static.go:6:75: pattern *.html: no matching files found
make: *** [Makefile:7: build] Ошибка 1
- Can’t understand how to solve this error, bcs it seems to be okay for others…
- I’ve go version go1.16 linux/amd64 installed
Hii @Muslimah
before execute make build
please run the below command to install the UI
dependency.
make dev-requirements
make ui-requirements
Thank you for so quick response!
I really appreciate your help!
I had errors while trying to execute make ui-requirements
command, that I couldn’t solve using npm audit fix
or npm audit fix --force
. However, execution of these commands in the ui
directory fixed the issue. By the way, is it okay to do so?
But unfortunately, I still have go embed error((
$ make ui-requirements
Installing UI requirements
up to date, audited 2121 packages in 8s
129 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
$ make build
Building ui
> chirpstack-application-server-ui@3.0.0 build
> react-scripts build
Creating an optimized production build...
Compiled successfully.
File sizes after gzip:
470.45 KB build/static/js/2.c34da569.chunk.js
52.03 KB build/static/js/main.97a28eae.chunk.js
23.56 KB build/static/css/2.e72d3014.chunk.css
791 B build/static/js/runtime-main.33db2bcb.js
116 B build/static/css/main.3f9ef032.chunk.css
The project was built assuming it is hosted at /.
You can control this with the homepage field in your package.json.
The build folder is ready to be deployed.
You may serve it with a static server:
npm install -g serve
serve -s build
Find out more about deployment here:
https://cra.link/deployment
Fetching Swagger definitions and generate combined Swagger JSON
Клонирование в «/tmp/chirpstack-api»…
remote: Enumerating objects: 3777, done.
remote: Counting objects: 100% (171/171), done.
remote: Compressing objects: 100% (133/133), done.
remote: Total 3777 (delta 78), reused 94 (delta 31), pack-reused 3606
Получение объектов: 100% (3777/3777), 2.68 MiB | 319.00 KiB/s, готово.
Определение изменений: 100% (2406/2406), готово.
Note: switching to 'v3.9.5'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
HEAD сейчас на a49efdc Add ReEncryptDeviceQueueItems method on AS interface.
mkdir -p build
go build -ldflags "-s -w -X main.version=3.15.0-test.1-1-g5384962" -o build/chirpstack-application-server cmd/chirpstack-application-server/main.go
static/static.go:6:82: pattern *.js: no matching files found
I tried to run it using docker (docker-compose run --rm chirpstack-application-server bash
), the same result
go build -a -installsuffix cgo -ldflags "-s -w -X main.version=3.15.0-test.1-1-g5384962" -o build/chirpstack-application-server cmd/chirpstack-application-server/main.go
make: *** [Makefile:7: build] Error 1
I realized now this problem occured since the Refactor SQL schema migrations from sql-migrate to golang-migrate + U… commit has been done.
I did the hard reset to previous commit. It did the trick for me and now app server is successfully running on my localhost.
Hii @Muslimah
I have clone chirpstack-application-server
and perform the build step and it’s working fine.
$ make build
Building ui
> chirpstack-application-server-ui@3.0.0 build E:\chirpstack-application-server\ui
> react-scripts build
Browserslist: caniuse-lite is outdated. Please run:
npx browserslist@latest --update-db
454.24 KB build\static\js\2.7e037a47.chunk.js
51.08 KB build\static\js\main.27461f3b.chunk.js
23.57 KB build\static\css\2.ff340785.chunk.css
789 B build\static\js\runtime-main.ce245b8e.js
116 B build\static\css\main.a2b7b0b6.chunk.css
serve -s build
bit.ly/CRA-deploy
Cloning into '/tmp/chirpstack-api'...
Receiving objects: 100% (3777/3777), 2.68 MiB | 975.00 KiB/s, done.
Resolving deltas: 100% (2406/2406), done.
You are in a 'detached HEAD' state. You can look around, make experimental
git switch -
HEAD is now at a49efdc Add ReEncryptDeviceQueueItems method on AS interface.
mkdir -p build
go build -ldflags "-s -w -X main.version=3.15.0-test.1-2-g6eb051c" -o build/chirpstack-application-server cmd/chirpstack-application-server/main.go
