go generate internal/static/static.go, generated static_gen.go,this file don’t have static.AssetInfo
[lora@localhost unb_app_server]$ make build
/internal/api/external
…/…/internal/api/external/external.go:181:14: undefined: static.AssetInfo
note: module requires Go 1.14
make: *** [build] Error 2
help me ,please
My recommendation is to use the provided Docker Compose based development environment:
https://www.chirpstack.io/application-server/community/source/
That environment comes pre-configured with all the tools needed to run make build
Hii @Paul_Chan
delete static_gen.go
file and regenerate using make internal/statics internal/migrations
command
