Hi when I’m trying to execute this:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
I end up with this error:
gpg: keyserver receive failed: End of file
any ideas please?
Thanks
any ideas please?
Thanks
That sounds like a network issue (e.g. keyserver.ubuntu.com can’t be reached).
Thanks brocaar,
I have checked and reset the network configuration but still getting this error.
Is there another way of getting these keys?
Cheers.
Does this work for you: http://keyserver.ubuntu.com/pks/lookup?op=get&fingerprint=on&search=0x1CE2AFD36DBCCA00?
You can then follow these instructions: http://redcrackle.com/blog/how-add-ubuntu-apt-get-key-behind-firewall.
Thanks again brocaar,
I have followed the instructions and it works, however when i finish and try to start the lora-app-server, i get this:
● lora-app-server.service - LoRa App Server
Loaded: loaded (/lib/systemd/system/lora-app-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2018-06-28 18:21:51 BST; 7s ago
Docs: https://docs.loraserver.io
Process: 4369 ExecStart=/usr/bin/lora-app-server (code=exited, status=1/FAILURE)
Main PID: 4369 (code=exited, status=1/FAILURE)
Jun 28 18:21:51 debian systemd[1]: lora-app-server.service: Failed with result ‘exit-code’.
Jun 28 18:21:51 debian systemd[1]: lora-app-server.service: Service hold-off time over, scheduling restart.
Jun 28 18:21:51 debian systemd[1]: Stopped LoRa App Server.
Jun 28 18:21:51 debian systemd[1]: lora-app-server.service: Start request repeated too quickly.
Jun 28 18:21:51 debian systemd[1]: Failed to start LoRa App Server.
Jun 28 18:21:51 debian systemd[1]: lora-app-server.service: Unit entered failed state.
any ideas please?
Cheers
Please do not mix multiple questions in one topic. This has already been asked and answered before: https://forum.loraserver.io/search
I try this, but in keyserver.ubuntu.com this key is not found.
I had the same issue but it was resolved when I tried different keyserver. Try one among the below keyservers:
Refer this link: https://rvm.io/rvm/security
