gRPC fails to name resolve using network load balance
I am use chirpstack on single node and no have problems, but for production I need to take a load balance. After add aws network load balance, I get to connect in web admin and my gateway in 1700 port. But some place on web admin I receive an error about name resolve. Any know this problem?
Detail on load balance, I connect in webadmin on xxx port and redirect to 8080 default port of chirpstack.
See my logs:
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.459141Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.462601Z DEBUG gRPC{uri=/api.ApplicationService/List}: chirpstack::api: Started processing request
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.462780Z INFO gRPC{uri=/api.ApplicationService/List}: chirpstack::api: Finished processing request status=“200” latency=196.491µs
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.463329Z DEBUG gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Started processing request
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.463480Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status=“200” latency=158.431µs
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.464035Z DEBUG gRPC{uri=/api.TenantService/Get}: chirpstack::api: Started processing request
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.464167Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status=“200” latency=141.641µs
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.464889Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.465680Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.465743Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.670314Z DEBUG gRPC{uri=/api.TenantService/Get}: chirpstack::api: Started processing request
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.670472Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status=“200” latency=175.011µs
Oct 21 12:12:09 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:09.672364Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:11 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:11.730450Z DEBUG gRPC{uri=/}: chirpstack::api: Started processing request
Oct 21 12:12:11 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:11.730581Z INFO gRPC{uri=/}: chirpstack::api: Finished processing request status=“200” latency=143.131µs
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.301941Z DEBUG gRPC{uri=/api.InternalService/Login}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.303912Z INFO gRPC{uri=/api.InternalService/Login}: chirpstack::api: Finished processing request status=“200” latency=1.985313ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.306203Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.450631Z DEBUG gRPC{uri=/api.InternalService/Profile}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.456484Z INFO gRPC{uri=/api.InternalService/Profile}: chirpstack::api: Finished processing request status=“200” latency=5.864788ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.458044Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.613388Z DEBUG gRPC{uri=/api.TenantService/List}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.627932Z INFO gRPC{uri=/api.TenantService/List}: chirpstack::api: Finished processing request status=“200” latency=14.556755ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.629404Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.777067Z DEBUG gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.779109Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status=“200” latency=2.055633ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.780215Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.922412Z DEBUG gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.924167Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status=“200” latency=1.768431ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.925517Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.939310Z DEBUG gRPC{uri=/api.TenantService/Get}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.942830Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status=“200” latency=3.495263ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.944130Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.953743Z DEBUG gRPC{uri=/api.TenantService/Get}: chirpstack::api: Started processing request
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.957900Z INFO gRPC{uri=/api.TenantService/Get}: chirpstack::api: Finished processing request status=“200” latency=4.166757ms
Oct 21 12:12:15 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:15.959500Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
Oct 21 12:12:16 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:16.070640Z DEBUG gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Started processing request
Oct 21 12:12:16 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:16.072662Z INFO gRPC{uri=/api.InternalService/GetVersion}: chirpstack::api: Finished processing request status=“200” latency=2.038223ms
Oct 21 12:12:16 ip-10-2-140-51 chirpstack[11424]: 2024-10-21T12:12:16.073923Z ERROR chirpstack::api: Log request error error=Error occurred while creating a new object: failed to lookup address information: Name does not resolve: failed to lookup address information: Name does not resolve
This is probably a configuration issue. E.g. you put the wrong hostname in your config.
