I am facing a similar issue while trying to run FUOTA-server.
Here is what I see when I run main.go example provided in the repo.
INFO[0396] storage: deployment updated id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0396] fuota: starting multicast class-c session setup for devices deployment_id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0397] storage: deployment created id=32636270-ead5-4c35-8f02-050afd10b42f
INFO[0397] storage: deployment device created deployment_id=32636270-ead5-4c35-8f02-050afd10b42f dev_eui=647fda000000cc4d
WARN[0397] [transport] transport: http2Server.HandleStreams failed to read frame: read tcp [::1]:8070->[::1]:57786: read: connection reset by peer
INFO[0397] finished client unary call grpc.code=OK grpc.method=Create grpc.service=api.MulticastGroupService grpc.time_ms=175.251 span.kind=client system=grpc
INFO[0397] fuota: multicast-group created deployment_id=32636270-ead5-4c35-8f02-050afd10b42f multicast_group_id=d45e8f64-46c4-4fe1-a172-83ee21562173
INFO[0397] fuota: add devices to multicast-group deployment_id=32636270-ead5-4c35-8f02-050afd10b42f
INFO[0397] fuota: add device to multicast-group deployment_id=32636270-ead5-4c35-8f02-050afd10b42f dev_eui=647fda000000cc4d multicast_group_id=d45e8f64-46c4-4fe1-a172-83ee21562173
INFO[0397] finished client unary call grpc.code=OK grpc.method=AddDevice grpc.service=api.MulticastGroupService grpc.time_ms=175.415 span.kind=client system=grpc
INFO[0397] fuota: starting multicast-setup for devices deployment_id=32636270-ead5-4c35-8f02-050afd10b42f
INFO[0397] fuota: initiate multicast-setup for device attempt=1 deployment_id=32636270-ead5-4c35-8f02-050afd10b42f dev_eui=647fda000000cc4d
INFO[0397] finished client unary call grpc.code=OK grpc.method=Enqueue grpc.service=api.DeviceQueueService grpc.time_ms=172.953 span.kind=client system=grpc
INFO[0397] storage: deployment log created command=McGroupSetupReq deployment_id=32636270-ead5-4c35-8f02-050afd10b42f dev_eui=647fda000000cc4d
WARN[0456] fuota: multicast class-c session setup reached max. number of attempts, some devices did not complete deployment_id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0456] storage: deployment updated id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0456] fuota: starting multicast enqueue deployment_id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0457] finished client unary call grpc.code=OK grpc.method=Enqueue grpc.service=api.MulticastGroupService grpc.time_ms=178.958 span.kind=client system=grpc
INFO[0457] finished client unary call grpc.code=OK grpc.method=Enqueue grpc.service=api.MulticastGroupService grpc.time_ms=183.58 span.kind=client system=grpc
INFO[0457] finished client unary call grpc.code=OK grpc.method=Enqueue grpc.service=api.MulticastGroupService grpc.time_ms=178.044 span.kind=client system=grpc
INFO[0457] storage: deployment updated id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2
INFO[0457] fuota: waiting for multicast-session to end for devices before sending fragmentation-session status request deployment_id=2b24b768-9fa8-4d77-ac0a-8fa78c01bbd2 sleep_time=1m3.448646743s
WARN[0457] fuota: multicast-setup reached max. number of attepts, some devices did not complete deployment_id=32636270-ead5-4c35-8f02-050afd10b42f
INFO[0457] storage: deployment updated id=32636270-ead5-4c35-8f02-050afd10b42f
INFO[0457] fuota: starting fragmentation-session setup for devices deployment_id=32636270-ead5-4c35-8f02-050afd10b42f
Here is a snippet from chirpstack-fuota-server.toml for event handler binding:
Application Server (integration) settings.
[application_server]
Event handler integration settings.
[application_server.event_handler]
# Payload marshaler.
# This defines how the HTTP payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="protobuf"
# HTTP handler settings.
[application_server.event_handler.http]
# IP:Port to bind the event handler server to.
bind="0.0.0.0:8090"
My chirpstack instance is running on 65.21.189.50, hence this configuration in the same file:
API integration settings.
[application_server.api]
# ChirpStack Application Server API server endpoint.
server="65.21.189.50:8080"
Under HTTP integration, I am using same IP as my ethernet interface IP and port 8090.
My device receives the downlink from FUOTA-server and the device sends an uplink in response to multicast setup request. However, fuota server is unable to receive uplinks from device. I have done HTTP integration. I guess the issue is related to this warning:
I am not sure where I am going wrong. Any suggestions to resolve this issue are much appreciated.
