gRPC over Nginx proxy
We are trying to use the gRPC API for a Chirpstack V3 instance (we cannot update it to V4 yet due to our production infrastructure). The instance runs on a VM and is accessible on port 443 behind an NGINX reverse proxy.
We have looked at the following resources for help:
We’ve tried updating our nginx configuration with the grpc_pass option like so:
server {
    listen 443 ssl http2;
    server_name localhost;
    ssl_certificate /path/to/cert.crt;
    ssl_certificate_key /path/to/cert.prv;
    # WebSocket configuration
    location ~ ^/api/(gateways|devices)/(\w+)/(frames|events)$ {
        proxy_pass http://localhost:8080/api/$1/$2/$3;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "Upgrade";
        proxy_read_timeout 86400s;
        proxy_send_timeout 86400s;
    location / {
        grpc_pass grpc://localhost:8080;
but we are still getting the following error when we try to connect to the instance over gRPC:
unable to authenticate to IP:443: rpc error: code = Unavailable desc = error reading from server: EOF
What are we missing in our configuration to make this work? Thank you.
Today I enabled port 8080 on the VM for testing purposes, and gRPC works using it, so it must be something missing in our nginx config.
i face the same problem when usinig python grpc client.
if i use grpc.insecure_channel(server) i must use host:port and the port must not be 443, if i have to use 443, maybe have to use secure client.
grpc.secure_channel(server, grpc.ssl_channel_credentials(trusted_certs))
The grpc_pass is for ChirpStack v4. For ChirpStack v3 the REST API is used + Websockets for the live events / frames.
You would need something like this:
			proxy_pass http://127.0.0.1:8080/api/$1/$2/$3;
		location / {
			proxy_pass http://localhost:8080;
Hi, could it be that you have enabled TLS on Chirpstack? I created the thread you linked before. You have to disable TLS in Chirpstack and only enable it in nginx.
Sorry, just to confirm, does that mean there is no way to use the GRPC API for Chirpstack V3 over nginx?
Are those the TLS options under [application_server.external_api]? If so, I have TLS disabled, but am still getting the same issue. When connecting over grpc, were you providing any sort of certificates or credentials?
After having some more time to look into the issue, I figured it out. There were two issues that prevented this from working:
  1. I was using an insecure gRPC connection to connect to an Nginx server that had SSL certs setup.
    I had to use cred, err := credentials.NewClientTLSFromFile("path_to_cert", "")
    and
    grpc.Dial(grpcHost, grpc.WithTransportCredentials(cred))
    to have Nginx accept the connection.
  2. The gRPC API endpoint was incorrect. The correct location for Chirpstack V3 is as follows:
location ~* /api(\.) {
Once I’ve made these changes, I was able to connect over gRPC on port 443.
Note: also make sure to enable http2 in Nginx like this:
 server {
