GW send data, but Bridge not processing
We are trying to configure the bridge to receive data from the gateway, but it never receives anything, I don’t know what else I can configure or look at, any suggestions?
Logs:
More info…
antenna using is:
A screenshot is not that helpful, next time please upload text.
Refer to and describe your setup.
https://www.chirpstack.io/project/architecture/
Where is the GB running, is it running in the gateway (local) or are you hosting is outside the gateway (extern)
If it’s running local, it should be a localhost address and not the ddns address.
If it’s extern your router might be having issues forwarding the messages to your “gateway-bridge”. Please check the appropriate settings on your router.
Not, my antenna connect via internet with my server.
hal@msi:/$ sudo tcpdump -AUq port 1700 -vv
tcpdump: listening on enp4s0, link-type EN10MB (Ethernet), capture size 262144 bytes
09:10:34.169957 IP (tos 0x0, ttl 55, id 31261, offset 0, flags [DF], proto UDP (17), length 139)
67.red-83-44-41.dynamicip.rima-tde.net.52625 > msi.1700: [udp sum ok] UDP, length 111
E…z.@.7…S,)C…wF…c…L?.IF.{“stat”:{“time”:“2020-10-28 09:10:33 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
09:10:35.961788 IP (tos 0x0, ttl 55, id 31262, offset 0, flags [DF], proto UDP (17), length 40)
67.red-83-44-41.dynamicip.rima-tde.net.45910 > msi.1700: [udp sum ok] UDP, length 12
E…(z.@.7…}S,)C…V…T.3…L?.IF…’…
09:11:12.602156 IP (tos 0x0, ttl 55, id 31263, offset 0, flags [DF], proto UDP (17), length 40)
67.red-83-44-41.dynamicip.rima-tde.net.51894 > msi.1700: [udp sum ok] UDP, length 12
E…(z.@.7…|S,)C…g…L?.IF…".*.
09:11:22.792816 IP (tos 0x0, ttl 55, id 31264, offset 0, flags [DF], proto UDP (17), length 40)
E…(z @.7…{S,)C…is…L?.IF…lD8
09:11:29.886631 IP (tos 0x0, ttl 55, id 31265, offset 0, flags [DF], proto UDP (17), length 290)
67.red-83-44-41.dynamicip.rima-tde.net.35620 > msi.1700: [udp sum ok] UDP, length 262
E…“z!@.7…S,)C…$…2/.Q…L?.IF.{“rxpk”:[{“tmst”:19706339,“time”:“2020-10-28T09:11:45.268917Z”,“tmms”:1287911524268,“chan”:1,“rfch”:1,“freq”:868.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“lsnr”:7.2,“rssi”:-54,“size”:23,“data”:“QFI/oACA9AII3KhcccQ7gBw39g5kB0w=”}]}
09:11:32.993008 IP (tos 0x0, ttl 55, id 31266, offset 0, flags [DF], proto UDP (17), length 40)
E…(z”@.7…yS,)C…J…L?.IF…[._q
If you observed, my antenna send data to my UDP 1700 port, this data captured.
This problem is when bridge not procesed the data.
Oct 28 09:05:28 msi systemd[1]: Stopping ChirpStack Gateway Bridge…
Oct 28 09:05:28 msi systemd[1]: chirpstack-gateway-bridge.service: Succeeded.
Oct 28 09:05:28 msi systemd[1]: Stopped ChirpStack Gateway Bridge.
Oct 28 09:05:28 msi systemd[1]: Started ChirpStack Gateway Bridge.
Oct 28 09:05:28 msi chirpstack-gateway-bridge[130644]: time=“2020-10-28T09:05:28Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“https://www.chirpstack.io/gateway-bridge/” version=3.9.2
Oct 28 09:05:28 msi chirpstack-gateway-bridge[130644]: time=“2020-10-28T09:05:28Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“127.0.0.1:1700”
Oct 28 09:05:28 msi chirpstack-gateway-bridge[130644]: time=“2020-10-28T09:05:28Z” level=debug msg=“backend/semtechudp: cleanup gateway registry”
My router open ports UDP 1700 and TCP 8081 to app only, open the port for all using?
Please change your GB-setting to bind to all or the IP address facing the “internet”
you gw bridge start listen localhost interface, and not listen external ones
Oct 28 10:35:02 msi systemd[1]: Stopped ChirpStack Gateway Bridge.
Oct 28 10:35:02 msi systemd[1]: Started ChirpStack Gateway Bridge.
Oct 28 10:35:02 msi chirpstack-gateway-bridge[133571]: time=“2020-10-28T10:35:02Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“https://www.chirpstack.io/gateway-bridge/” version=3.9.2
Oct 28 10:35:02 msi chirpstack-gateway-bridge[133571]: time=“2020-10-28T10:35:02Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“217.216.66.248:1700”
Oct 28 10:35:02 msi chirpstack-gateway-bridge[133571]: time=“2020-10-28T10:35:02Z” level=fatal msg="setup backend error: new backend error: listen udp error: listen udp 217.216.66.248:1700: bind: cannot assign requested address"
Oct 28 10:35:02 msi systemd[1]: chirpstack-gateway-bridge.service: Main process exited, code=exited, status=1/FAILURE
Oct 28 10:35:02 msi systemd[1]: chirpstack-gateway-bridge.service: Failed with result ‘exit-code’.
Oct 28 10:35:02 msi systemd[1]: chirpstack-gateway-bridge.service: Scheduled restart job, restart counter is at 5.
Oct 28 10:35:02 msi systemd[1]: chirpstack-gateway-bridge.service: Start request repeated too quickly.
Oct 28 10:35:02 msi systemd[1]: Failed to start ChirpStack Gateway Bridge.
This config fail, with localhost not fail.
Not the IP address of your router. The IP of the interface connected to the network.
Probably 192.168.1.X
or just use 0.0.0.0:1700
This my config, without errors. … But my bridge not procesing nothing…
With my local ip
udp_bind = “192.168.0.18:1700”
bridge not log error, but not processing anything either
my bridge log:
Oct 28 10:46:07 msi systemd[1]: chirpstack-gateway-bridge.service: Succeeded.
Oct 28 10:46:07 msi systemd[1]: Stopped ChirpStack Gateway Bridge.
Oct 28 10:46:07 msi systemd[1]: Started ChirpStack Gateway Bridge.
Oct 28 10:46:07 msi chirpstack-gateway-bridge[133899]: time=“2020-10-28T10:46:07Z” level=info msg=“starting ChirpStack Gateway Bridge” docs=“https://www.chirpstack.io/gateway-bridge/” version=3.9.2
Oct 28 10:46:07 msi chirpstack-gateway-bridge[133899]: time=“2020-10-28T10:46:07Z” level=info msg=“backend/semtechudp: starting gateway udp listener” addr=“192.168.0.18:1700”
Oct 28 10:46:07 msi chirpstack-gateway-bridge[133899]: time=“2020-10-28T10:46:07Z” level=debug msg=“backend/semtechudp: cleanup gateway registry”
Oct 28 10:46:07 msi chirpstack-gateway-bridge[133899]: time=“2020-10-28T10:46:07Z” level=info msg=“integration/mqtt: connected to mqtt broker”
Oct 28 10:47:07 msi chirpstack-gateway-bridge[133899]: time=“2020-10-28T10:47:07Z” level=debug msg=“backend/semtechudp: cleanup gateway registry”
… every minute the same…
Any idea?
You may have a network connectivity issue (firewall, etc). Try connecting to 1700 UDP using netcat on the gateway itself, then try the same from off-gateway. You should see an error line in the logs.
Not errors…
I think not compatible in versions between antenna(gw) and server(bridge), is possible?
You’re using TCP in your netcat test.
Hi all,
I still have not been able to solve the problem, is it necessary that port 8000 of the networkserver be exposed to the outside?
Any idea?
Thanks.
In log antenna gateway is:
JSON up: {“stat”:{“time”:“2020-11-11 10:27:36 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
INFO: [down] the last 10 PULL_DATA were not ACKed, exiting application
What does this mean?
No, you don’t need to open this port at all.
It means that your gateway is not receiving messages from network server.
It’s right like this at this moment, as you didn’t reach to connect your gateway to the network server.
The problem must be located at any setup in server, that makes that the gateway bridge doesn’t receive the packages.
