Hello, I’m having some problems in order to process the data from downlink payload.
I was following the documentation in https://www.chirpstack.io/application-server/integrations/mqtt/#scheduling-a-downlink and prepared two samples for testing in Node-Red:
First example:
"confirmed": true,
"fPort": 10,
"data": "NTAw"
Second example:
"confirmed": true,
"fPort": 10,
"data": "",
"object": {
"txinterval": {"1": 500}
With the first example, the device receive the data, but I can only print in the terminal with the Serial.write(LMIC.frame + LMIC.dataBeg, LMIC.dataLen);
I don’t know how to gather that data and use it for other things in my code. My objective is to send a number via node-red into my device that will manage the TX_INTERVAL for the os_setTimedCallback function.
With the second example the device doesn’t receive anything.
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen) {
Serial.println(F("Received "));
Serial.println(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
This is from the ttn-OTAA example of MCCI LoRaWAN LMIC library
When I receive a downlink package the LMIC.dataLen is > 0, in order to see the data I use Serial.write(LMIC.frame + LMIC.dataBeg, LMIC.dataLen);
My question is… there is another function or method in order to obtain the value I’m sending?
