Have problem with frequency Downlink
I run Chirpstack on Docker. I want to use Lorawan with 433Mhz. I set [Gateway-profiles] is 433mHz SF=7 BW=125kHz
Uplink is working but downlink is not. In Json send from Chirpstack Server to my Gateway is missing frequency for tx packet and Spreading-factors always SF12
This is log pkt_fwd of my gateway
 RXTX~ (TXPKT): [down] {"txpk":{"imme":true,"rfch":0,"powe":14,"ant":0,"brd":0,"freq":0,"modu":"LORA","datr":"SF12BW125","codr":"4/5","ipol":true,"size":44,"data":"YHUXASaABgAAAcl18DRuNfjLK8ZmlkuVesmfma4ut/xdk2LfBOMijpcsHRc="}}
RXTX~ (TXPKT): [down] {"txpk":{"imme":true,"rfch":0,"powe":14,"ant":0,"brd":0,"freq":0,"modu":"LORA","datr":"SF12BW125","codr":"4/5","ipol":true,"size":18,"data":"oHUXASaQCAABylddExkfO2H8"}}
This is log on Chirpstack server
Imgur
Downlink with ACK send by Chirpstack Server is correct freq 433mHz, but Donwlink data send by user have freq 0mHz
is the LoRaWAN regional band selected correctly in your chirpstack-network-server.toml ?
Thank you @ eugenev This is my chirpstack-network-server.toml file
# See https://www.chirpstack.io/network-server/install/config/ for a full
# configuration example and documentation.
# This file is for the EU433 band. See the examples/ folder for more
# configuration examples.
[postgresql]
dsn="postgres://chirpstack_ns:chirpstack_ns@postgresql/chirpstack_ns?sslmode=disable"
[redis]
url="redis://redis:6379"
[network_server]
net_id="000000"
[network_server.band]
name="EU433"
  frequency=433000000
  min_dr=0
  max_dr=12
  frequency=433175000
  min_dr=0
  max_dr=12
  enabled_uplink_channels=[0,1,2,3]
server="tcp://mosquitto:1883"
[join_server.default]
server="http://chirpstack-application-server:8003"
[geolocation_server]
server="chirpstack-geolocation-server:8005"
I don’t know why Downlink for auto ACK packet is have right frequency 433Mhz, but Downlink queue data send by user always have frequency 0Mhz. I saw it in txInfo.
datarate number is not equal spreading factor
I changed it like this. is it correct?
min_dr=0
max_dr=5
frequency:0
Please check your device-profile. A common mistake is to leave the RX2 freq. set to 0. For ABP devices, the properties set in the device-profile are used (and ChirpStack will align with the global config later using mac-commands). After making changes to the device-profile, make sure to re-activate your ABP device!
