Having trouble decoding Sontay SORA Sensors
I’m using a decoder sent to me by the manufacturer, but I keep getting the follwoing error when I try to decode a packet
js vm error: (anonymous): Line 12:7 Unexpected identifier (and 16 more errors)
Can;t for the life of me work it out and not getting much response from the manufacturer. If anyone can help I’d be most grateful.
 *	Sontay LoRaWAN Packet Decoder script	*
 *	v1.1									*
 *	Compatible with Sontay LoRaWAN sensors	*
function decodeUplink(input) {
  let SENSOR_TEMP = (1 << 1);
  let SENSOR_RH = (1 << 2);
  let SENSOR_CO2 = (1 << 3);
  let TOTAL_DATA_SLOTS = 4;
  var data = {};
  var slot = 0;
  let sensors = (input.bytes[0] << 8) | (input.bytes[1] & 0xFE);
  var vBat = ((input.bytes[1] & 0x01) << 8) | input.bytes[2];
  data.Battery = vBat / 100;
  if(vBat >= 330)
	  data.BatteryStatus = "Good";
  else if(vBat < 300)
	  data.BatteryStatus = "Poor";
  else
	  data.BatteryStatus = "OK";
  for(let i = 1; i < 16; i++) {
    var d = (input.bytes[3+(2*slot)] << 8) | (input.bytes[4+(2*slot)]);
	if(d > 0x7FFF)
		d -= 0xFFFF;	// Correct for a negative value
    switch(sensors & (1 << i)) {
      case SENSOR_TEMP:
        data.Temperature = d / 100;
        break;
      case SENSOR_RH:
        data.Humidity = d / 10;
        break;
      case SENSOR_CO2:
        data.CO2 = d;
        break;
      default:
        continue;
    if(++slot > TOTAL_DATA_SLOTS)
      break;
  return {
    data,
    warnings: [],
    errors: []
Looks like they gave you a TTN decoder.
Chirpstack has a different API.
function Decode(fPort, bytes, variables)
Thanks. Have modified it accordingly and got it working.
