Sorry, was an oversight on my end. I didn’t update the name inside the region file. Now all is working with the region file for 2 sub-bands. Thanks
- chirpstack.toml
Enabled regions.
Multiple regions can be enabled simultaneously. Each region must match
the ‘name’ parameter of the region configuration in ‘[[regions]]’.
enabled_regions=[
“us915_23”,
“us915_2”,
“us915_3”,
- region_us915_23.toml
This file contains an example US915 example (channels 16-23 + 66).
[[regions]]
ID is an use-defined identifier for this region.
id=“us915_23”
Description is a short description for this region.
description=“US915 (channels 16-23 + 66)”
description=“US915 (channels 16-23 + 66) & (channels 24-31 + 67)”
Common-name refers to the common-name of this region as defined by
the LoRa Alliance.
common_name=“US915”
Gateway configuration.
[regions.gateway]
# Force gateways as private.
# If enabled, gateways can only be used by devices under the same tenant.
force_gws_private=false
[regions.gateway.backend]
  # The enabled backend type.
  enabled="mqtt"
  # MQTT configuration.
    # Topic prefix.
    # The topic prefix can be used to define the region of the gateway.
    # Note, there is no need to add a trailing '/' to the prefix. The trailing
    # '/' is automatically added to the prefix if it is configured.
    topic_prefix="us915_23"
    server="tcp://$MQTT_BROKER_HOST:1883"
    username=""
    password=""
    # Quality of service level
    # 0: at most once
    # 1: at least once
    # 2: exactly once
    qos=0
    # Clean session
    clean_session=false
    # Client ID
    # broker. A client id must be no longer than 23 characters. If left blank,
    # a random id will be generated by ChirpStack.
    client_id=""
    # Keep alive interval.
    # This defines the maximum time that that should pass without communication
    # between the client and server.
    keep_alive_interval="30s"
    ca_cert=""
    tls_cert=""
    # TLS key file (optional)
    tls_key=""
# Gateway channel configuration.
# Note: this configuration is only used in case the gateway is using the
# ChirpStack Concentratord daemon. In any other case, this configuration
# is ignored.
[[regions.gateway.channels]]
  frequency=905500000
  bandwidth=125000
  modulation="LORA"
  spreading_factors=[7, 8, 9, 10]
  frequency=905700000
  bandwidth=125000
  modulation="LORA"
  frequency=905900000
  bandwidth=125000
  modulation="LORA"
  frequency=906100000
  bandwidth=125000
  modulation="LORA"
  frequency=906300000
  bandwidth=125000
  modulation="LORA"
  frequency=906500000
  bandwidth=125000
  modulation="LORA"
  frequency=906700000
  bandwidth=125000
  modulation="LORA"
  frequency=906900000
  bandwidth=125000
  modulation="LORA"
  frequency=906200000
  bandwidth=500000
  modulation="LORA"
  spreading_factors=[8]
  frequency=907100000
  bandwidth=125000
  modulation="LORA"
  frequency=907300000
  bandwidth=125000
  modulation="LORA"
  frequency=907500000
  bandwidth=125000
  modulation="LORA"
  frequency=907700000
  bandwidth=125000
  modulation="LORA"
  frequency=907900000
  bandwidth=125000
  modulation="LORA"
  frequency=908100000
  bandwidth=125000
  modulation="LORA"
  frequency=908300000
  bandwidth=125000
  modulation="LORA"
  frequency=908500000
  bandwidth=125000
  modulation="LORA"
  frequency=907800000
  bandwidth=500000
  modulation="LORA"
Region specific network configuration.
[regions.network]
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=1
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=8
# RX2 frequency (Hz)
rx2_frequency=923300000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# ADR is disabled.
adr_disabled=false
# Minimum data-rate.
min_dr=0
# Maximum data-rate.
max_dr=3
# Enabled uplink channels.
# Use this when ony a sub-set of the by default enabled channels are being
# used. For example when only using the first 8 channels of the US band.
# Note: when left blank / empty array, all channels will be enabled.
enabled_uplink_channels=[16, 17, 18, 19, 20, 21, 22, 23, 66]
# Rejoin-request configuration (LoRaWAN 1.1)
[regions.network.rejoin_request]
  # Request devices to periodically send rejoin-requests.
  enabled=false
  # The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
  # uplink messages. Valid values are 0 to 15.
  max_count_n=0
  # The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
  # seconds. Valid values are 0 to 15.
  # 0  = roughly 17 minutes
  # 15 = about 1 year
  max_time_n=0
# Class-B configuration.
[regions.network.class_b]
  # Ping-slot data-rate.
  ping_slot_dr=8
  # Ping-slot frequency (Hz)
  # set this to 0 to use the default frequency plan for the configured region
  ping_slot_frequency=0
- docker-compose.yml
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:4
restart: unless-stopped
ports:
- “1700:1700/udp”
volumes:
environment:
- INTEGRATION__MQTT__EVENT_TOPIC_TEMPLATE=us915_23/gateway/{{ .GatewayID }}/event/{{ .EventType }}
- INTEGRATION__MQTT__STATE_TOPIC_TEMPLATE=us915_23/gateway/{{ .GatewayID }}/state/{{ .StateType }}
- INTEGRATION__MQTT__COMMAND_TOPIC_TEMPLATE=us915_23/gateway/{{ .GatewayID }}/command/#
depends_on:
- mosquitto
